lugs breaking? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-13-2004, 04:58 PM   #1 (permalink)
View tater_tot's Photo Gallery
lugs breaking?
i was driving alogn this mornin and kept hearing a popping noise. i get home and someone says "you think it could be bc there is only two lugs holding this rim on?" ............. apparently they all broke off while i was driving since last night bc they were all there last night. i guess my question is have any of you ever had a problem with your lugs braking. and what could have probably caused it. thanks for any replies you may have
tater_tot is offline   Reply With Quote
Old 04-13-2004, 05:02 PM   #2 (permalink)
']['R][) Camry
View ']['R][) camry's Photo Gallery
Re: lugs breaking?
Wow man, that is crazy
They might have not been tight enough.. they could have been too tight (more then 80 foot pounds of pressure)
Or someone jacked 3 of them... some ppl are sick minded
My Web page...:
http://www.user.dccnet.com/cgalazka/
Located:
Vancouver, BC Toke Toke Pass... BC green
']['R][) camry is offline   Reply With Quote
Old 04-13-2004, 05:55 PM   #3 (permalink)
i didnt know that about 80ft lbs of pressure...... how sad... lol. im goin to meineke tomorrow when i get off work to get em to check it out. i don think i should do too much driving though with it like this.
Old 04-13-2004, 05:56 PM   #4 (permalink)
No Fat Bitches
iTrader Score: 10 reviews
View PtBaller's Photo Gallery
^ Yea what he said. Your lugs were probably loose.
More than 80 lbs is too much pressure? I know that 77 or so is the torque spec for the lugs but my car vibrates when they my lugs are torque to that spec. I retightened my lugs to 100 foot pounds and the vibrating stopped.
^ Volk Racing CE28s 19x8.5/8 for sale
PtBaller is offline   Reply With Quote
Old 04-13-2004, 06:03 PM   #5 (permalink)
']['R][) Camry
well I am not 100% sure.. I have Enkei RF1 Mags and they told me where I got them to tighten the nuts to 80 foot pounds... idk if it matters what type of rim you have...
good luck!
My Web page...:
Located:
Old 04-13-2004, 06:17 PM   #6 (permalink)
ook well i have some excel tz10 wheels. and its not just the nut that came off its the whole bolt that broke (in case there was any confusion)
ps thanks for all the replies im taking everything into concideration
Old 04-13-2004, 07:53 PM   #7 (permalink)
No Fat Bitches
This happened to me with my old wheels. The 2 lugs on one wheel fell off because they weren't tight enough and the weight snapped off the wheel studs. Thats what happened to your studs after you were driving around with only two lugs.
Old 04-13-2004, 08:06 PM   #8 (permalink)
Sold out for a Max
TheMajesticking's Avatar
View TheMajesticking's Photo Gallery
I had three lugs break off on me once. I believe it was because I didn't have any hub-centric rings. All of the weight was on the lugs instead of the hub.
-Chris
TheMajesticking is offline   Reply With Quote
Old 04-13-2004, 08:31 PM   #9 (permalink)
View foompla's Photo Gallery
do you have alloy rims?
foompla is offline   Reply With Quote
Old 04-13-2004, 09:31 PM   #10 (permalink)
hub centric ring..... hmmm.. you kno i kinda was wondering about that. that could have very well been the case. of course all of these things seem very logical.
as for this, honestly i dont know. i just asked my friend and he said they are.
Old 04-13-2004, 10:30 PM   #11 (permalink)
mystery dude
View earthmike's Photo Gallery
When I had lug trouble with a tire shop *cough*Tires Plus*cough* the problem was that they really over-tightened and partially stripped the lugnuts, putting extra stress on the studs. The lug studs had broken off when I tried to tighten the damaged nuts (by hand).
Why is it so frickin' hard to find a good garage you can trust?
--Mike
earthmike is offline   Reply With Quote
Old 04-13-2004, 10:43 PM   #12 (permalink)
I'm a Mac
zoni's Avatar
View zoni's Photo Gallery
my friend's cavalier breaks lug studs like it is its job... we've broken/stripped 4 studs on there already... damn shitty GM
Dave Zoni
Latest 3S-GTE Swap Pics
zoni is offline   Reply With Quote
Old 04-14-2004, 12:01 AM   #13 (permalink)
geeeeeeez glad mine arent comin apart like that. but yea basically thts where my trouble started was with one tht i had to replace cuz this guy at a garage used an impact wrench to put the tire back on the car and over tightened it. but its only been on this one wheel tht im havin trouble with. i suppose its just time to start replacin em.
Old 04-14-2004, 08:31 AM   #14 (permalink)
View Camdaddy's Photo Gallery
hmm....I don't know..its a tough call about that. technician do go to automotive school for their training. I went to Lincoln Technical Institute. When it comes to Lugs its common that they break even if your're a 20 year tech. They break mainly because it was torque improperly, rust buildup, last person that put them on cross threaded them on. All lugs should be hand started before using an impact wrench. Then torqued in a star pattern a few times. Not properly torquing your lugs on the wheels could cause wear to the rotors fast.
" The Replacement for Displacement is Technology. "
Camdaddy is offline   Reply With Quote
Old 04-15-2004, 03:00 PM   #15 (permalink)
welp got it replaced today cost me around 65 dollars. though i coulda done it myself for about 10 bux max. but considerin i didnt have time or patience and not to mention am just plain lazy i suppose i got off decent. thanks for all the suggestions guys and i think i figured out the problem. i had forgotten one of the lugs had broken off when i was changing my brake rotors and i think it has to do with the hubcentric ring i keep hearing about. i figure with tht lug being missing and there not being a hubcentric ring put to much pressure on the studs causing them to break. thank you guys for all the input.
