Spring and Strut Saga.....
I atempted to install new struts and springs for my Gen 3 Camry over the Easter weekend..and boy I was in for trouble...If you ever order KYB GR2s Sealed Struts. Your going to need new Spring Seats and Lower Strut Mount Bearings also, thats just for the Front though, the rears are okay. I ordered mines through SHOX.COM and they didn't tell me I needed that...so when I got them I looked at them and they looked nothing like the OEM struts I have on the car. I called KYB and found out that I needed additional Parts #SM5125 (bearing) & SM 5173 (spring seat). I found them locally, luckily KYB was located in IL. So I got the parts through a distributor locally. That solved the problem for the Fronts. But the rears were a totally different story. I was going to install my Whiteline Swaybar also. So beforeahand I bought new sway bar links for the rear from Toyota. Got a great deal on them since I worked at Sears Auto Center. Nothing outta the ordinary since its a 12 year old car with stock everything in the rear. Broke one bolt of the sway bar bushing. The Sway bar links were rusted and crap...took good hour to get the sway bar off.......called it a day...have to pick up more parts tommorrow to make things work hopefully. Just a word of advice...things will break for sure...on suspension on old cars. When I am at work things are on hand and parts come quick...when at home everything is a hassle but its fun in a way.
" The Replacement for Displacement is Technology. "
