Originally posted by daza_mate
how can i test the coil?
Using an ohmmeter, measure coil primary resistance between the ignition coil terminals. Resistance cold should be approximately:
0.38 - 0.46 ohms
Measure coil secondary resistance between the ignition coil terminals and the distributor cap high tension lead terminals. Resistance cold should be approximately:
2S-ELC and 3S-FE; 1983-88; 7.5 - 10.5 K ohms
3S-FE; 1989-91; 7.7 - 10.4 K ohms
Also check the coil to see if its cracked or leaking oil.
