5S-FE oil change interval - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-15-2004, 09:57 PM   #1 (permalink)
Phi
Whine Connoisseur
Phi's Avatar
View Phi's Photo Gallery
Okay, I just took a quick look at the recommended oil change interval of my 5S-FE off of Toyota's site. It says 8000km (4970 miles) Does that seem kinda high to any of you? I'm used to an interval closer to the 5000km (3100 mile) range.
The interval of my 1MZ-FE is 6000km (3728 miles) which is acceptable.
2000 Camry Sedan
2-Wheel-Drive
4-Cylinder
Non-Turbo-Charged
Oil & Filter Service
An Oil & Filter Service is required every 6 months/8,000 km, whichever occurs first. Every Oil & Filter Service includes the following operations: Replace engine oil & filter. Remove & inspect air filter element. Lubricate locks, latches & hinges Confirm lights, horn & wipers function properly. Check coolant, brake & washer fluid levels. Check tires and adjust pressure as required.
TN Map - Add Yourself
Phi is offline   Reply With Quote
Old 04-15-2004, 10:45 PM   #2 (permalink)
I get angry when Im sober
Stealth's Avatar
View Stealth's Photo Gallery
yeah just do it every 3k miles itll probably last longer and just use cheap shit since you're changing it so often
1995 Silverleaf Metallic Camry LE Automatic beater
1987 Buick Grand National
Stealth is offline   Reply With Quote
Old 04-15-2004, 11:03 PM   #3 (permalink)
Druken Postwhore
TRDragoon's Avatar
View TRDragoon's Photo Gallery
ive seen people doing oil change after passing 23,000km....
8000km goes for any model after 2000.
one of the master mechanic from japan told me, you really dont need to change airfilter,oil filter.....but he's saying that becuz in japan you hardly keep a car thats over 50 000km on it.
The AE92 Master
UniQue_N_RaRe
TRDragoon is offline   Reply With Quote
Old 04-16-2004, 01:11 AM   #4 (permalink)
prana's Avatar
View prana's Photo Gallery
my girlfriend has a gen4 camry and the dealer told her every 5,000 miles...i was like WHAT??
they said it was ok cause most of her miles were highway...
good way to shorten the life of your engine
99 Camry Le
prana is offline   Reply With Quote
Old 04-16-2004, 06:01 AM   #5 (permalink)
View woshiagni's Photo Gallery
Highway miles are less wear and tear on the car but I don't think that makes it okay to do oilchange at 5000 mi...
I do almost all freeway miles and I change my oil every 3000 mi. It comes out to about one oil change every 7 weeks.
woshiagni is offline   Reply With Quote
Old 04-16-2004, 12:27 PM   #6 (permalink)
vw owner ;)
View alchu's Photo Gallery
If you guys are using synthetics like mobil 1, check out this Synthetic Oil Life study.
http://neptune.spacebears.com/cars/stories/mobil1.html
They took a car and ran oil tests every 1,000mi. They ran the same oil (mobil 1) for 18k miles! They're doing an amsoil test now.
Interesting results and recommendations. They recommend 8k miles between oil changes on cars that don't use oil. I'll be following VW's recommendation of 10k mi oil changes on my vr6, but changing the filter every 5k miles (adds about 1 to 1.5 qt of new oil at that change)
I'll probably do the same for my GF's gen3 camry.
Interesting to note that people doing 3k mile oil changes may be introducing more wear than people who run their oil longer.
"Engine wear actually decreases as oil ages. This has also been substantiated in testing conducted by Ford Motor Co. and ConocoPhillips, and reported in SAE Technical Paper 2003-01-3119. What this means is that compulsive oil changers are actually causing more engine wear than the people who let their engine's oil get some age on it. "
Allan
alchu is offline   Reply With Quote
Old 04-16-2004, 12:52 PM   #7 (permalink)
Zzzz
CrawlingEye's Avatar
View CrawlingEye's Photo Gallery
good post, alchu.
I'm thinking about changing to mobil 1 with my next oil change and sticking with that.
-mark
'93 Camry LE (5S-FE)
CrawlingEye is offline   Reply With Quote
Old 04-16-2004, 01:16 PM   #8 (permalink)
vw owner ;)
yeah I'm really appreciative of their study. it's important to back up reasons with fact, and 1k mile oil sample tests to blackstone labs is one way to get good numbers. Much better than the "it's cheap insurance, change your oil every 3 mos/ 3000 miles" That generates too much waste, esp in light of the other studies that confirm that 3000 mi changes are actually WORSE for your car.
Old 04-16-2004, 04:23 PM   #9 (permalink)
Location: San Diego CA, Glen Cove NY,Fairford UK,Cedar Rapids, IA
Gameroom cash: $281092
View csaxon's Photo Gallery
I started using Mobil I back in 1974. The can actually listed a 25000 mile change interval. The car service people screamed and it was removed about a year later. It was originally only a 5w20 and I ran it in a 1974 Mercedes 450SL. It was too thin for the chain tensioner and I would hear it slap on startup but once running it was fine. I finally sold the car last year after 29 years of trouble free service. I changed oil and filter every 5K.
I should probably mention that the reason I even tried Mobil I in the first place was because I watched a technician putting it into one of the jet engines of a plane I was flying back in 1974.
It worked fine until I fixed it!
csaxon is offline   Reply With Quote
