I have a 1999 Camry Solara V6 w/ oil leak.
To remedy the leak, all of the following seals were replaced during recent timing belt and water pump replacement.
Crank Seal 90311-40022
Cam Seal (2) 90311-38034
Front valve cover gasket
Rear valve cover gasket
T-cover Seal Top 11329-20010
T-cover Seal Center 11319-20010
T-cover Seal Lower 11328-20020
Rear valve cover PCV valve w/ grommet.
The crank seals and valve cover do not leak anymore and when I look at the passenger side of the engine, everything is clean w/ no signs of oil leak.
For more detailed pics:
http://ardiansa.com/1mzfe_leak/
If you look at the pics I posted, the leak came from the driver's side and flow down which made me think it's coming from the top right side of the engine somewhere.
Initially, I saw slight leak coming from the oil filler cap, so I bought an OEM one and replaced that. Now it still leaks like before.
Any one can point to what other gaskets/seals need to be changed?
Thanks again.
