well here u go guys.. hope this helps (sorry about the blurry pics)
it was pretty easy, the only real tough thing was cutting down the shaft in the limited space with a large hacksaw.. so needless to say it took a little while..
oh and the Levoc had an adapter on the inner shaft so that either an oval or round shaft could use this shifter... so you should be all good no matter what shape your gen's shaft is
here are the two screws you have to unscrew first. they are facing the dash side.
when they are unscrewed, just yank it straight up and it should come off in your hands.. you'll have to yank hard cuz of the O/D wires. if you want you can cut the OD wires if you plan on ever putting the OEM shifter back on for some reason.
this is the inner and outer shaft with the shifter off (notice the OD wires sticking out)
heres the Levoc shifter i got ($80USD expensive, i know)
now i know why they said to use a pipe cutter.. my friend washed his car and finished, and i was still cutting the shafts with the hacksaw..
but heres the outer shaft cut down, i took off about
2.5 inches
2.5 off the inner shaft..
connect the OD wires with the one from the shifter, and test the button. if you don't want it to engage at that position, then switch the wires around.
drop the shifter down onto the shaft, and heres the new shifter in place, sorry about the blurry-ness. to attach it to the shaft, you have all the hardware you need. screws, allen wrenches, etc should all come with the shifter. this is where you may need to actually use the instructions
one other thing about the levoc too, it comes with a plastic shaft that goes over the metal shaft. cut that down and use that because thats what helps move the p-r-n-d-2-l indicator correctly. heres what i mean, you can see the big space, which doesnt move the hole enough to show you what gear you're in. of course we all dont need that anyways, right?
heres a night pic with my 194 LED bulb behind the shifter plate
if you guys have any questions or anything, let me know!
the whole process took a couple hours or so, and i was changing my oil at the same time..
