It takes about 5 mins. To remove your AT pedal, first you have to unhook the return spring. Then remove a pin holding the pedal to the brake master cylinder. Last thing is to remove a 12mm nut/bolt way up holding the pedal to the bracket.
Installation of the MT pedal is the reverse of the above. I found mine at a junkyard.
Why do you want to know?? Are you planning a tranny swap? Cuz if you're not it would be really ghey to put an MT pedal on an AT car. It does not serve any useful purpose. Also, the foot well will look really empty with that small brake pedal.
_________________
Jeff - SXV10
All Show + No Go = Drive Slow
Pictures Mods List
<font size=-1>[ This Message was edited by: SpectraBlueCam on 2002-04-11 21:13 ]</font>
