the motor mounts will not be the same... you will need all the v6 motor mounts. there are 3+tranny mount. front lower, rear lower, and torque strut + tranny mount.
oh my god a whole list?
well i think i made a complete list somewhere already... but oh well...
=1mz motor
=1mz standard ecu
=1mz wiring harness, complete, not cut. preferably standard tranny, but it doesnt matter.
=standard v6 tranny
=motor mounts mentioned above
=right axle (sometimes will come with a motor mount cause the =bearing is tough to get out)
=left axle
=right and left wheel hubs/steering knuckles
=right and left rotors
=right and left calipers
=power steering pump
=alternator
=a/c compressor
=v6 igniter
=new spark plugs - platinum tipped
=new oil filter
=new oil
=new gear oil
=new Automatic Tranny Fluid (for power steering)
=new coolant
=radiator decision...
use 4cyl radiator? - you need a few couplings from home depot and some extra radiator hose
use v6 radiator? - you need the radiator and the hoses
use mk3 supra radiator? - you need the radiator and some couplings and extra hose
=use the 4cylinder radiator fan...
=you need a new clutch kit - performance or oem??? you decide, i like spec stage 3 but ratko would have gone with stage 2 if he could do it over again
=flywheel - performance or oem? fidanza, aasco, or stock
=slave cylinder should come with tranny
=need to get a clutch line (i got one from autozone, a hard line and bent it to fit around the engine bay. the hard line provides hard clutch pedal, better than the stock rubber hose. which is also an option, along with ss braided line which is more $$)
=need a master cylinder
=need a clutch pedal
=brake pedal
=center console if you want it to appear stock
=shift boot, see above
=lots of wire
=connectors to plug into the ecu cause we will be missing a plug. we will have to wire up each pin for like 7 or 8 pins...
=ummmm i know i must be leaving some shit out... maybe, maybe not. ill check back later... after i go to the bar and come back drunk
