Speedometer Poblem - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-30-2004, 05:18 PM   #1 (permalink)
View .tony. .riot.'s Photo Gallery
Speedometer Poblem
I installed the Indiglo Gauges yesterday, and everything was fine. When I left school today around 3, the RPM needle won't move, and the MPH needle kind jumps all the way to the speed I'm going at, or just doesn't move.
I'm guessin they somehow got de-magnetized or something. How could that happen? If that's the reason for this, what can I do?
.tony. .riot. is offline   Reply With Quote
Old 04-30-2004, 05:40 PM   #2 (permalink)
Go camry goooooo
DrewsCam's Avatar
Gameroom cash: $184780
View DrewsCam's Photo Gallery
You might have messed up a spring, i did similar when i installed my glow guages, now my gas isnt as acurate, a full tank is just past 3 qtrs, go check to see if the needle rubs on the guage itself, if so tape the guage down so its sits flush.
See if that helps
11/19/2007 Gen 6 08 Camry SE.
Rockland Toyota / Scion Showdown 4.0 Sept 26th
DrewsCam is offline   Reply With Quote
Old 04-30-2004, 05:42 PM   #3 (permalink)
I checked the needles before closing everything, it's already taped and it didn't rub anywhere.
Old 04-30-2004, 07:35 PM   #4 (permalink)
View warlock's Photo Gallery
i had the same porblem i know you arent subost to do this but i pulled the needals and glued the indiglos down.befor i did this i
got the motor to temp and marked wher everything was. after instala i got it to the same temp and replace everything but the mph. for that all i did was put the car in drivego at about 5 mph and put it on at 0.now im 4 mph slower thin it sayes but thay dont stick.
94 Scepter 1MZ-FE
< TN Type [R]ice Club>RICERS UNITE!! Join Type R..latest faction of TN!!
.....http://www.toyotanation.com/forum/sh...d.php?t=105457
warlock is offline   Reply With Quote
Old 05-01-2004, 05:22 PM   #5 (permalink)
View I4 to V6 Swap's Photo Gallery
I had this problem. I pulled the needles off, and lightly put them on. If they are pushed on too tight, they won't move. You barely have to put them on. Also, if the indiglo gauges are bubbling up near the needle base, it will rub and the needles won't move either.
I4 to V6 Swap is offline   Reply With Quote
Old 05-16-2004, 04:49 PM   #6 (permalink)
I fixed it today.
The needles were rubbing with the gauges. It looks like the tape I used was pretty cheap, haha.
