For $6 k you can find a decent camry, they are everywhere thank goodness, but i'd avoid anything made AFTER 2006. Toyota changed generations and these later cars are full of problems: ABS clunk, "drive by wire" headaches, the infamous accelerator pedal recall. Simply examine the older posts here about the problems people have had with these later gen camrys - Forget it.
the 1999-2000 model camrys are very good. Try and find a Japanese camry not a kentucky camry (you can tell by the VIN, i think the japanese ones have a "J" somewhere in the VIN but im not sure). The paint on the Japanese camrys is far superior - the paint on my 2002 V6 kentucky camry is crappy, it will scratch if you brush up against it.
2001 and later are the sludge engines. If the owner ignored Toyota's oil erroneous change interval and changed every 3000, the engine will probably be in good shape. If they changed every 7,000 like toyota said, and used only dino not synthetic, you may risk buying a car with a sludged up engine.
There's no reason to avoid these cars necessarily. i have a 2001 V6 solara and a 2002 v6 camry, changed the oil every 3000 and have had no issues. but caveat emptor,, i have seen engines from people that weren't good about changing their oil (ex girlfriend had a 2001 Sienna with this 1FMZE V6 engine, it smoked so badly and quit running and needed the pans taken off and everything cleaned out for $500 due to sludging, The engine recovered nicely, runs fine, it even smogs - but now it uses one qt of oil every 400-500.). .)but if an engine is sludged up it usually manifests itself in performance, smoke, engine smell, and tailpipe residue (oily and wet vs dark or light powdery grey, which is how it is supposed to look inside the tailpipe)
pre-2007 camrys, most of them have a timing belt not a chain like later models so know this might have to be changed. Other then that, and the sludging issue, if the car has less then 100,000 on it you probably can't lose whatever you buy. If it looks good and drives good, it probably IS good - it's a camry! (An allmighty camry?)
