Help locating weird sound. - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-02-2004, 12:31 PM   #1 (permalink)
Zzzz
CrawlingEye's Avatar
View CrawlingEye's Photo Gallery
My car has this squealing noise that it makes when I first start driving it, only when I'm hitting the throttle.
It lasts for about 5-10 minutes then goes away, after driving.
However, warming the car up does not solve the problem.
I've already confirmed that it's not the timing belt.
There are 2 new axle assemblies on it, so the CV joints/boots aren't the problem.
I've recently replaced the plug wires and plugs, so I know they're current (although, I'm guessing that shouldn't create any issues like above).
I know I still need to do 2 things, but I'm unsure if it's a related problem. I'm getting my tranny flushed friday (fluid's brown, but no metallic pieces), and I have a twisted fuel line.
I was assuming it was the fuel line, but have been told by a couple shops that it doesn't seem like that would do it.
What'd you guys think?
Oh yeah, the sound is definitely coming from the front of the car.
-mark
'93 Camry LE (5S-FE)
CrawlingEye is offline   Reply With Quote
Old 05-02-2004, 01:06 PM   #2 (permalink)
amerikim's Avatar
View amerikim's Photo Gallery
Could be water pump beginning to go out or belt issues or check your power steering hydraulics. I think its water pump imho.
old faithful
amerikim is offline   Reply With Quote
Old 05-02-2004, 02:09 PM   #3 (permalink)
Zzzz
I hope not, the timing belt and pump were just recently replaced.
I'll have them checked though.
-mark
Old 05-02-2004, 04:31 PM   #4 (permalink)
I'm a Mac
zoni's Avatar
View zoni's Photo Gallery
starter maybe, how many miles?
Dave Zoni
Latest 3S-GTE Swap Pics
zoni is offline   Reply With Quote
Old 05-02-2004, 06:21 PM   #5 (permalink)
Zzzz
154k.
-mark
Old 05-02-2004, 06:29 PM   #6 (permalink)
View woshiagni's Photo Gallery
Is the noise constant or on and off?
You're absolutely sure it's not the timing belt? It sound like it could be tightened down improperly or to the wrong spec.
woshiagni is offline   Reply With Quote
Old 05-02-2004, 06:30 PM   #7 (permalink)
View Meisner's Photo Gallery
Power steering belt is loose.
When the fluid is cold, there is more of a load on the pump. This causes the belt to slip a little (source of the squealing noise). After it warms a little, the pump doesn't create as much of a load and the belt stops slipping.
It's also possible it's the alternator. American cars do that a fair amount due to the load from the alternator.
Have the belts checked first. That's an easy and cheap fix.
1996 Turbocharged Camry 5S-FE (4 cyl)
http://www.meisners.net/camry
Meisner is offline   Reply With Quote
Old 05-02-2004, 07:05 PM   #8 (permalink)
Zzzz
The belt was replaced shortly before I bought the car, along with the power steering pump. I confirmed this with a mechanic who looked over the car before I bought it (I bought it maybe a month or a month and a half ago).
I recently had it looked at while I went in for the fuel line to get checked out, and they said the timing belt was in fine condition and it wasn't loose at all.
-mark
Old 05-02-2004, 07:06 PM   #9 (permalink)
Zzzz
I'll have 'em take a look at it when I take it in Friday for the tranny flush. Thanks, Meisner.
-mark
Old 05-03-2004, 11:19 AM   #10 (permalink)
View Calvin327's Photo Gallery
I got something really similar to that as well crawlingeye. Itd like a wierd vibration noise, no matter how fast I go I hear it. Its hard to tell if its coming from the wheel or from under the hood. I know for sure its near somewhere on the driver's side though. When I stop at a light it tends to vibrate causing a very strange knocking noise. When I drive and lift my foot off the throttle it makes this other noise as if I was going over a speed bump. Dunno what the hell it is. Any feedback is appreciated.
Thanks,
Calvin
Calvin327 is offline   Reply With Quote
Old 05-06-2004, 06:28 AM   #11 (permalink)
Why do you guys keep mentioning the timing belt??? The timing belt is a toothed belt and it controls the valve timing relative to the crank. It really can't be 'loose', per se. There is a tensioner that keeps it tight. But more importantly, if it was loose, he'd be having much worse problems than a squealing noise. It would run like crap.
He mentioned the power steering pump was replaced...that mean the p/s belt was loosened and retightened. That is a tough belt to get good and tight. I still say it's the p/s belt.
Old 05-06-2004, 06:50 AM   #12 (permalink)
The Regenerator
ekpolk's Avatar
View ekpolk's Photo Gallery
Exactly. The timing belt is toothed and is inside the engine; it's not one of those you see on the "outside" of the engine. A freshly installed "external" belt (alternator, P/S, or serpentine if that's what your engine has) is a prime candidate for just the squealing you describe. Such belts often stretch and limber up not long after being installed. It seems that this issue has improved with time, but ten or more years ago, a belt replacement was routinely a two-visit procedure. First, you'd get the belt done, then a couple weeks later, it would need to be re-adjusted. Get it taken care of soon. If this is the origin of your sound, the rubbing that generates the squeal can quickly cause "glazing" of the belt-pulley contact surface (from the heat and rubbing). This, in turn, can lead to early cracking, failure, and ultimately another new belt.
ekpolk is offline   Reply With Quote
Old 05-06-2004, 02:30 PM   #13 (permalink)
Zzzz
Re: noise
Originally posted by mykngdom4avvti
I have to agree with the other people that posted. This is probably a timing belt. It might be a surpintine belt or an accessory drive belt. Possibly an alternator, or power steering problem.
Open the hood and stand infront of the car. Have someone start it.
Starting it won't replicate the problem. The problem occurs while I press once I start driving for the first couple minutes. Like I said, it goes away after about 5 minutes.
I checked my timing belt today for tension and gave it a surface eyeballing (without removing it) and everything appears ok. The belt below that (I'm unsure of what that one is for) seems to be alright as well, but I can't get a very good view of that at all.
The car goes in tomorrow for the tranny flush, so I'll see how everything goes after that.
-mark
Old 05-06-2004, 04:34 PM   #14 (permalink)
Um....I don't think you're talking about the timing belt. Did you have to take off a plastic cover before you could see any part of the "timing belt"? The timing belt on any car is completely enclosed and protected by some sort of cover. It is usually difficult to remove these covers (many bolts that are tough to get to).
I belt you're looking at the alternator and A/C compressor belt and calling that the timing belt. The other belt you couldn't see too well is the power steering belt.
My money is still on the power steering belt!
Old 05-06-2004, 05:23 PM   #15 (permalink)
Zzzz
I'm starting to agree, Meisner. When I went out today and grabbed a flashlight, the power steering belt (smaller belt, kind of hidden) looked slightly worn (from what I could see from a distance). If not the mechanic, saturday my brother will be down (who is a mechanic himself) who will look at it for me too.
-mark
