Looking at a Solara - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-02-2011, 05:52 PM   #1 (permalink)
View NDFORSPD's Photo Gallery
Looking at a Solara
Ive gotta keep my voice lowered as to not make my home sites(all GM based) not jealous! Im looking at an 01 Solara V6, 240k kms, 5spd. Just wondering several things:
There is an engine light on, I believe its due to something with the evap system. the owner says she has gone to a cpl toyota techs and no one can pinpoint the cause of the eng light. however the car runs fine?
secondly, the timing belt was done around 110k, its now at 240k, obviously the car is very close to needing it done, is there A. any good write ups WITH this info/pics/step by step instructions for the V6(ive only found 4 banger inst). B. How much longer can i eeek out not doing the belt? C. What should I expect to pay for parts?
Is there any trouble spots with this car? i have driven strictly GM vehicles for the last 10 yrs(grand prix gtp, Cadillac STS, A few Camaros/Trans Ams). Im hoping this will be a good foot forward into the Import scene
NDFORSPD is offline   Reply With Quote
Old 03-03-2011, 02:07 PM   #2 (permalink)
View AlmightyCamry777's Photo Gallery
Changing V6 Timing Belt Pics and the $270 Coil Connector
I helped my ex-wife buy her 2001 V6 solara because she did not know what car to buy. It was bought used in 2005 with 42,000 mi on it and has gone over 100,000 trouble free miles more since then.
Anyway a check engine light due to the evap system is not, in my opinion too serious. In other words it is annoying but not going to strand you. You need to go to another mechanic if they cannot diagnose a simple evap problem even with OBD II. I have my own OBD II reader bought from harbor fregiht for $30 (i dontt hink they sell it that cheap anymore) and it has paid for itself several times over. One time i cleaned the throttle body and the CEL came on, i used my obd II reader (itflashes the code 3 times in series of three, then resets the CEL.) the CEL shut off and did not return. At least get the codes from the dummy mechanics somaybe you can post it here or do a google search and find out what to replace.
I did the timing belt on my own V6 camry and also the TB on her V6 solara. Set aside half a day, have your parts and tools ready, and follow the article and you can do it yourself. The engineering and ergonomics on the 1fmZE engine is excellent, and the timing belt change is very straightforward for a V6, so long as you have all your tools ready it ought to go smoothly for you.
If i had your car and your mileage, i'd assume the water pump and both pulleys had never been changed, and change them also. Even though they changed the t-belt i'd assume that's all they changed when they did it.
You asked about trouble spots, the biggest one is this engine was part of the great toyota sludge recall. If the engine seems ok and sludge free, looks ok, smells ok (no burning oil smell) and the deposits in the tailpipe are dark or light grey and dry, the engine is probably ok. This engine was designed with inadequate PCV ventilation, which means that you cannot let the engine go much more then 3000 miles without an oil change because sludge will form quickly if you are using dino oil (regardless of what anybody tells you).
Like i said we bought a 2002 V6 camry and the 2001 solara, and simply ignored the recall letter because i had changed the oil in both of them at 3000 miles with out fail and was reasonably sure there was nothing wrong with them. You'll have to examine this engine, or have it examined (at least pull the front plugs, or better yet thefront valve cover if you can, and look for evidence of sludging), unless you want to take a chance (i did, twice, and havent had any sludging problems - or any other problems of any kind for that matter).
AlmightyCamry777 is offline   Reply With Quote
Old 03-03-2011, 05:18 PM   #3 (permalink)
View YADDADAIMSAYIN's Photo Gallery
come join us on solaraguy.com for all your solara-related questions. There's plenty of knowledge there specifically for your car. good luck!
2004 Toyota Solara SLE
ll CP-e Intake ll TRD Lowered ll TRD Exhaust ll TRD RSB ll 20/5 Tints ll Custom Grille ll Alpine Headunit ll Rocksford Fosgate Amp ll 2 10" JBL Subs ll 6000k HID ll Satisfied Driver ll
http://i67.photobucket.com/albums/h292/yaddadaimsayin/banner1.jpg
YADDADAIMSAYIN is offline   Reply With Quote
