Originally posted by grapefury
here's a few tips:
1) lighten weight, take out seats, spare tire, whatever else you can. diet for a day or two
2) don't run with a full tank of gas (related to the weight issue) usually a 1/4 is used
3) rims over 17" and performance don't mix, go back to steelies if you have to. sticky tires if you can
do all of the above for weight savings
also do an oil change, possibly a tranny flush as well if you're due for one
change you spark plugs and spark plug wires
Advance your timing a few degrees (don't go overboard on this!)
fab up a CAI or if you dont' have enough time then just get a cone filter and bolt that on real quick.
That seems like pretty much all you can do in a day or two.
If thats not enough for you and you really wanna do a semi-serious mod that you can do in a day or two they have this little nitrous "Cheater system" its like a 35shot i think and it is the simplest system to bolt on. Check it out
