Hello, I have lurked around in the past but never signed up. Now I did as I have several questions. I drive a TDI (diesel) New Beetle and I do all my work myself except for major work, which I have none so far. I also do timing belts and pump swaps for other TDI owners. So that's a brief background about me.
I did search and the results was too huge to dig thru it but I found some interesting posts. Anyway I have a few questions. My wife drives 1999 Camry 4-cylinder engine. I don't know what are the specs or engine codes for it. Any information will help so I know what engine code/type to watch for when I start reading up in this forum.
The dealer told us that the brake fluid is lifetime and never needs to be replace. (BS sirens going off in my head.) I bought the Motive PowerBleeder so I could flush the brake fluid for both cars. The only question I have is where to go and get blue stuff. So that I can track it. Well, clear will do as brake fluid is already yellowing. Also what DOT number is used. VW uses DOT 4. So what does our Camry use? (I know it is on the cap but I am work and she's at work.)
There is 70,000 miles on the engine and I do timing belts for TDI so I want to try to do a timing belt on this gasser. What am I looking for? Any special tools? I saw this website and it is great but I don't know where to go from there.
http://www.yotarepair.com/Timingbeltinstructions.html
What parts are needed to replace? The water pump as been replaced at 54,000 under warranty. So I don't think I need to replace it at 100,000 miles. How often does a timing belt have to be replaced? I am assuming 100K.
One last thing about the timing belts, on the VW TDI, I always adjust the timing so it is at a sweet spot. Do you have to adjust it afterwards?
And finally, where and what is a good repair manual? I use the Bentley manual for my Beetle. I see several people mentioned Haynes but is it complete and including all the information you need. The reason I asked is that they do have some manuals for some VW and the people over at the VW forums say they are not good for experts only for shade tree mechanics. Bentley only does European cars so no Japanese.
Thank you for your help.
