2001 Camry Instrument cluster light replacement - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-21-2011, 11:27 AM   #1 (permalink)
View aladvid's Photo Gallery
USA 2001 Camry Instrument cluster light replacement
Help, I'm trying to find out the best way to replace the light bulbs for the Instrument cluster panel on a 2001 Toyota Camry (4 cyl). Initially (a few months ago) part of the dash/instrument panel lighting went out, but last evening the other light went out. The lights still do work for the radio & heating/AC knobs section, only the lights for the Speedometer/Odometer section have gone out. The dimmer switch still works for the Heating area, so I'm assuming that there is no problem with the fuses...just the dash bulbs. What's the best way to replace them? I'm assuming that I must remove the instrument cluster & it's outer coverings to get to them. Are there any videos or possibly a step by step breakdown that could help me with this? Thanks much!
aladvid is offline   Reply With Quote
Old 03-21-2011, 02:04 PM   #2 (permalink)
BMR
Deputy of Mayberry
BMR's Avatar
Gameroom cash: $351953
View BMR's Photo Gallery
I don't know if there's a DIY for a 2001. But this one is for a gen3 Camry, which is probably very similar.
BMR is offline   Reply With Quote
The Following User Says Thank You to BMR For This Useful Post:
aladvid (03-22-2011)
Old 03-21-2011, 02:16 PM   #3 (permalink)
Thanks so very much! I will give it a try within the next few days (Weather permitting)..!
Old 03-21-2011, 05:47 PM   #4 (permalink)
Gameroom cash: $304355
This DIY for your generation 4 should show you how to remove your car's gage pod to get to and replace the bulbs.
http://www.toyotanation.com/forum/t88355.html
Mike
The Following User Says Thank You to Mike Gerber For This Useful Post:
Old 03-22-2011, 02:27 PM   #5 (permalink)
Thanks Mike!
Old 03-22-2011, 05:29 PM   #6 (permalink)
Thanks again Mike, that worked like a charm! Easiest dashboard-cluster Light replacement I ever did! 20 minutes. Thanks for your help!
Old 03-23-2011, 03:06 PM   #7 (permalink)
You're welcome.
Mike
