without removing the engine, the only thing i can think for you to try is this: loosen and/or remove , as needed, the engine and transmission mounts and rotate the engine a few degrees. You will not be able to rotate it very far, naturally, because of the CV driveaxles and all the other stuff attached. But you may be able to rotate it far enough to get a wrench on those manifold bolts.
Another thing to try, will removing the valve cover give you just enough space?
if you remove any mounts you probably know you have to support the drive train with a jack, good luck!
