real figures - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-14-2002, 09:01 AM   #1 (permalink)
View mndthrshr's Photo Gallery
Okay, i've read enough of the 5S-FTE vs 3S-GTE battles to totally confuse myself.
are there any REAL figures here?
does anyone have dyno'd horsepower or 1/4mile times???
Be careful guys. He may be running a stage 2 enhanced sticker kit!!!!
mndthrshr is offline   Reply With Quote
Old 04-14-2002, 09:10 AM   #2 (permalink)
also, throw out times and power for stock 4cyl and v6
Old 04-14-2002, 09:12 AM   #3 (permalink)
There is no substitute.
EKam's Avatar
Gameroom cash: $700765
iTrader Score: 6 reviews
View EKam's Photo Gallery
Your question here is very vague. First of all of all are you asking stock motor vs stock motor comprison? 5S-FTE is never a stock motor because it never came with a turbo from the factory. Second of all there are a lot of different variation of stock 3S-GTE engine depending which year/model they came off from. So it would be hard to compare the two due to differences in aftermarket parts and tunings.
I suggest you go on google.com and do some search for the two engines and answer the question yourself. This way you will learn more from it rather than trying to get a simple answer.
18/6/08 - Sayonara Kamuri!
EKam is online now   Reply With Quote
Old 04-14-2002, 09:41 AM   #4 (permalink)
i'm not needing that specific of stats. and i'd rather know what a real person is getting on a turbo'd 5S-FE, i know steve's crumped before he got it dyno'd. i dont know who else has done the burien kit. i know karma has done a custom turbo. does anyone know what kind of specs he's running now.
Old 04-14-2002, 09:54 AM   #5 (permalink)
EKam's Avatar
With that turbo kit on a stock 5S-FE, it will not get you anything higher than from a stock V6 figures.
Read my sig for figure I put on the wheel.
Old 04-14-2002, 09:59 AM   #6 (permalink)
which kit do you have?
i know others have gained significally higher amounts with higher amounts of boost
Old 04-14-2002, 10:40 AM   #7 (permalink)
EKam's Avatar
I have a V6.
You won't be able to up the boost by anything more than 1-2psi unless you build up the motor or get a bigger turbo with intercooler. It's not as simple as pressing the button.
Old 04-16-2002, 12:18 AM   #8 (permalink)
View speedemn's Photo Gallery
Burien Turbo for the 5S-FE runs at 5-7 psi max. on the stock engine. Anything more, you'd have to upgrade the bottom end of the 5S-FE.
At 5-7 psi the dyno numbers will be at about what a stock V6 Camry is (145 - 150 fwhp and ~160 lb.ft)
2003 BMW 540i 6-spd
2008 Toyota Rav4 Limited V6
2005 Mazda 3 Sport GT 5-spd (just sold)
1995 Nissan Maxima SE 5-spd... Best ET: 13.8... Best trap: 99mph (Gone)
1993 Toyota Camry LE (Gone)
speedemn is offline   Reply With Quote
