I have had my 18 inch rims for a while. When I bought them, the guy told me to rotate them after 8000 miles.
It has been 8000 miles, and I was curious when he meant rotate them, does he just mean switch the back tires with the front tires? That would be real easy for me because I installed them myself anyway.
Is there anything special I have to do? I'm curious because the guy told me to take it to a place to rotate them for me, but I figured I could do it myself.
Take the passenger side tires and switch them and take the driver side tires and switch them...That simple...Look for bad tire wear and nicks and scratches in your rims and stuff other than that you should be all set!.
you can reach me on AIM @ budking52r
1996 Camry 2.2L
Waiting until I graduate to buy a 2005 Toyota Tundra V8!
The CORRECT way to rotate tires is to bring the rear tires to the front without switching the sides, and to bring the fornt tires to the rear and switching sides (i.e. front driver side to rear passenger side and front passenger side to rear driver side). If you take a look at your owners manual, that is the recommended tire rotation pattern.
I'm SUPER, thanks for asking;
All things considered I couldn't be better I must say.
I'm feeling SUPER, no, nothing bugs me;
Everything is SUPER when you're...
You cannot switch the sides because it will mess up your car! Right....I think that is what I was trying to say...You cannot switch sides because they are radials...Doing so would screw up your steering and possibly burn out your tranny!
_________________
1996 Camry 2.2L
Some Mods but not enough to race with need more cheap ways to create more HP
<font size=-1>[ This Message was edited by: budking686 on 2002-04-15 12:38 ]</font>
As SBC said, the typical rotaion pattern calls for a front to back swap first, then a diaginal swap (ie. front left to rear right). However, if your tires are directional (which is what the arrows mean), a front to back swap is your only choice.
Budking, please explain how you can burn your tranny from changing the tires from one side to another?????? Moreover, it has NOTHING whatsoever to do with the fact that they are radials - that's not even relevant to the discussion.
Danny, like I said, OPEN UP YOUR OWNERS MANUAL and read this for yourself. Since OEM tires are not directional tires, follow that pattern only if you have non-directional tires. If you do have directional tires, then just swap front to back like Phi said.
I think SBC and Bud were sorta trying to say the same thing here. More than likely you have directional tires on your rims. So you cannot swap left to right at all. The way to rotate would be to go rear left to front left and vice versa and then rear right to front right and vice versa.
2003 BMW 540i 6-spd
2008 Toyota Rav4 Limited V6
2005 Mazda 3 Sport GT 5-spd (just sold)
1995 Nissan Maxima SE 5-spd... Best ET: 13.8... Best trap: 99mph (Gone)
1993 Toyota Camry LE (Gone)
Yes, Speedemn is right. You have directional tires if there are arrows pointing which way they should spin. In this case you can only go from front to back, and back to front. Do not switch sides. Go from left back to left front, and vice-versa. Right back to right front, and vice-versa. That is the only way you can rotate directional tires.
