TRD sway bar - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-07-2004, 10:44 PM   #1 (permalink)
View Calvin327's Photo Gallery
TRD sway bar
Which one is the one that fits the 3rd gen camry?
Part #: 00602-48830-010 or 00602-48800-101
And where is it the cheapest?
P.S. I have a 94 camry 5sfe
Thanks,
Calvin
Calvin327 is offline   Reply With Quote
Old 05-08-2004, 01:14 AM   #2 (permalink)
Luc
View Luc's Photo Gallery
Neither, TRD never made a RSB for the Gen3/Gen3.5, though you may modify the -48830-010 to make it fit...supposedly.
1998 Camry LE V6 S/C
2006 RAV4 LTD V6 AWD
Luc is offline   Reply With Quote
Old 05-08-2004, 01:40 AM   #3 (permalink)
Music nerd?
View Warped's Photo Gallery
The 97-01 sway bar will fit...as long as you use Gen 3 bushing brackets instead of the Gen 4 ones they supply with the bar...you can use your old ones or buy new ones for a few bucks.
Warped is offline   Reply With Quote
Old 05-08-2004, 02:49 AM   #4 (permalink)
Sweet n' Lowdown
BLUEMEANIE's Avatar
Gameroom cash: $112650
iTrader Score: 9 reviews
View BLUEMEANIE's Photo Gallery
The Whiteline bar is cheaper. The only difference is that the TRD bar is an adjustable 2 setting bar, street/track. The Whiteline bar falls between the TRD bar's settings as far as stiffness.
imho the Whiteline bar is sufficient but in hindsight I would have liked the track setting on the TRD bar a little better. Most people say its too stiff on the track setting. ...tho I'm the type who doesn't give a shit about comfort.
06 NB tC - OG Team HAMSTER - SUPERCHARGED
BLUEMEANIE is offline   Reply With Quote
Old 05-08-2004, 10:17 AM   #5 (permalink)
almc2242's Avatar
View almc2242's Photo Gallery
Dude, if you are planing to install a TRD bar. Go for it. It works great. I have a 1997 Toyota RAV4 with front TRD Sway Bar and Addcco Rear Bar. You just step on the gas and it will go where ever you tell it to go. Oh, BTW, no clean man, but they work. Good Luck.
almc2242 is offline   Reply With Quote
Old 05-08-2004, 08:59 PM   #6 (permalink)
Thanks for all the replies guys I really appreciate it. I found the bar actually on this site, http://www.toyotaparts4u.com/solara_rear_sway_bar.htm I hope this is the right one to get. It didn't say if it was adjustable. But I believe it is, so basically all I need to do is buy some gen 3 bushing brackets and I'm all set right. My next question is I've heard that all bars (whiteline and TRD sway bars) squeak! I have also heard of methods such as using a certain type of grease, others also used some sort of tape and grease. I am still confused what I should use to limit the squeaking. Also is there another place that is cheaper than the website I found?
Thanks again,
Calvin
Old 05-08-2004, 09:06 PM   #7 (permalink)
Lives For The Curves
View nort0188's Photo Gallery
Hold up now... a Gen1 Solara RSB will fit a Gen3 Camry with the only change being the bushing brackets? That is the coolest news I've heard in a loooonnngggg time! Should probably get the Whiteline endlinks too though.
If torque actually won races, wouldn't we all be driving diesels?
nort0188 is offline   Reply With Quote
Old 05-09-2004, 12:13 AM   #8 (permalink)
almc2242's Avatar
Thanks again,
Calvin
Dude, I got your back. Go to http://www.suspension.com They have everything you need regarding bushings, grease. And best of all. They have great prices. Funny, my TRD Sway Bar is orange. Anyway, it's as strong as nails.
Old 05-09-2004, 01:08 PM   #9 (permalink)
Music nerd?
About the squeaking...I searched and found out that marine grade lithium grease and teflon tape solves people's squeaking problems on their sway bars.
Old 05-09-2004, 05:03 PM   #10 (permalink)
That Geeky Star Wars Girl
ripley's99's Avatar
View ripley's99's Photo Gallery
i have had my TRD rear sway bar on track setting since i installed it on the first day...but then again i autocross so i knew the tail end would want to step out in a hard turn, and i know my car well and what to do, how to countersteer & not end up in a ditch/wrecked.
as far as the ride being stiff...i noticed only that the car turns in better & body roll is cut down somewhat. ride quality is not harshly effected at all, in fact when my mother rode with me after it was installed, she didn't even know i had done anything to the car
but if you are unfamiliar w/oversteer & understeer then you most likely need to start out w/a street setting on the bar and learn how the car will behave. start w/baby steps is the best way if you are inexperienced.
as for the squeaking i suggest using only the marine lithium grease, you can get it at wal-mart for like $5 for a big can. i regrease my bushings every 6 months and have only heard slight squeaking when it is time to regrease them.
if you have to get new bushings anyways you can order the black carbon impregnated ployurethane ones which do not require greasing and do not squeak from www.energysuspension.com.
Good Luck
Keri
99 Camry SXV20 5S-FE "Darth Maul" TRD Grocery Getter
89 MR2 AW11 4AG-ZE "R2-D2" Project nearing completion ...
"Darth Vadar" Super Secret Sith Power Project Car
ripley's99 is offline   Reply With Quote
Old 05-09-2004, 11:35 PM   #11 (permalink)
Thank you very much that is exactly what I need ripley;s 99, also thank you for the info about the grease warped. I intend to buy the TRD bar and get those bushings from energysuspension.
Again thanks!
Calvin
Old 05-10-2004, 06:24 AM   #12 (permalink)
almc2242's Avatar
Those bushings come with your TRD Bar, so don't worry. What doesn't come with your bar is the grease. For that you would have to go to Suspension.com.
Old 05-10-2004, 01:22 PM   #13 (permalink)
Music nerd?
^^ He has a Gen3, so he'll need Gen3 bushings. The bar comes with Gen4 bushings.
Old 05-10-2004, 08:20 PM   #14 (permalink)
Can you guys confirm for me that we are talking about the TRD Rear Sway bar for a SOLARA? I never read anything about a Solara on this post, but the above link was for a Solara bar. It sounded like you guys meant a 97-01 Camry... I don't know shit about Gen4's, so if they are interchangable with the Solara, that'd explain it. Could you guys tell me if the TRD RSB for Solara fits Gen3 Camry so long as you use Gen3 brackets, with a yes or no answer...
Old 05-10-2004, 08:21 PM   #15 (permalink)
slowamatic noob
a94autoCamry's Avatar
Gameroom cash: $149910
View a94autoCamry's Photo Gallery
i hope so, but we gonna have to wait for someone eles's answer... good luck with the project calvin..
calvin remember what i told you last night :
tires + rims (cuz its the most expensive) , then CAI (more cheap), the the RSB ( then u'll be set for some mountain runs ) ....and only put on ur tires + rims when ur really planning to run the mountain, use ur stock ones on the street
slow white - "no show and no go"
a94autoCamry is offline   Reply With Quote
