Corner lights always on - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-08-2004, 08:09 PM   #1 (permalink)
View icefeather's Photo Gallery
My taillights and coner lights are always on, im wondering if thats normal, i've seen other camries (not sure if its gen 3 or 4) without corner lights being turned on whitle driving......im just curious about it
BTW, i have a gen 3 LE V6
icefeather is offline   Reply With Quote
Old 05-08-2004, 08:54 PM   #2 (permalink)
Lives For The Curves
View nort0188's Photo Gallery
Um.... are they switched on? The middle setting will put on all lights except your headlights. Personally, I like driving with them like that, I think it looks tight as hell with the amber sidemarkers but no headlights. And the less I use my headlights the longer they'll last
If torque actually won races, wouldn't we all be driving diesels?
nort0188 is offline   Reply With Quote
Old 05-08-2004, 11:21 PM   #3 (permalink)
No, the switched is at the normal position (day driving, instrument panel not illuminated) .....so at dawn i don't bother turn the swtich because i have corner as well as tail
Old 05-09-2004, 12:11 AM   #4 (permalink)
Old 05-09-2004, 12:12 AM   #5 (permalink)
View .tony. .riot.'s Photo Gallery
I have a Gen 3 LE 4Cyl. and I can turn them off just fine. But I always drive with the corner lights on and the fog lights on.
.tony. .riot. is offline   Reply With Quote
Old 05-09-2004, 12:32 PM   #6 (permalink)
is it normal for lights on instrumental panel to flicker when i close my windows? (powered)
Old 05-09-2004, 02:21 PM   #7 (permalink)
nub
spydrvnm's Avatar
View spydrvnm's Photo Gallery
in my 93 xle the lights are all off if i turn the switch to the totally off position. most of the time i dont though.
do they flicker or dim? mine dim when i'm closing all my windows at once.
spydrvnm is offline   Reply With Quote
Old 05-10-2004, 08:08 AM   #8 (permalink)
Maybe dim is a better wrod to describe it, they dim when I close just "ONE" window......
Old 05-11-2004, 04:52 AM   #9 (permalink)
I'm a Mac
zoni's Avatar
View zoni's Photo Gallery
the lighting in general will dim when you use the power windows... if it dims really bad i would suggest having your alternator checked out... i think advance autoparts or autozone can check the alternator.
ICE, i dont know what is up with your corner lights... probably a malfunction in the headlight switch in the steering column. I usually know what is up with all electrical problems, but this one stumps me. it has to be a bad switch... there is no other way. only toyota can fix this one. OR you can TRY buying a new switch and installing it. but that involves removing the airbag, and steering wheel, and then taking the old one off and putting it all back together. you would have to get the part from a dealer though too...
Dave Zoni
Latest 3S-GTE Swap Pics
zoni is offline   Reply With Quote
