clock and radio presets not staying in memory - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-10-2004, 04:42 PM   #1 (permalink)
View rizzo's Photo Gallery
My clock settings and radio station presets are not staying in memory after I turn off my car. Fuse is o.k. and battery is charged. This first happend after I installed an aftermarket power antenna as the motor on my oem antenna burned out.
Could the wiring of the aftermarket antenna be causing the problem?
Where else can I check?
1995 Toyota Camry LE 2.2 Automatic
rizzo is offline   Reply With Quote
Old 05-10-2004, 07:42 PM   #2 (permalink)
amerikim's Avatar
View amerikim's Photo Gallery
could be battery contacts...Did it to me when I first picked up my car.
Now if the last thing you installed was that antenna, back the install out and see if the problem goes away.
old faithful
amerikim is offline   Reply With Quote
Old 05-11-2004, 02:00 AM   #3 (permalink)
Gameroom cash: $199835
View swegyptian's Photo Gallery
No constant power. Your 12v ignition is powering both for some reason. Is the deck stock?
www.swegyptian.com
swegyptian is offline   Reply With Quote
Old 05-11-2004, 02:18 AM   #4 (permalink)
Sweet n' Lowdown
BLUEMEANIE's Avatar
Gameroom cash: $112650
iTrader Score: 9 reviews
View BLUEMEANIE's Photo Gallery
yup. what he said.
06 NB tC - OG Team HAMSTER - SUPERCHARGED
BLUEMEANIE is offline   Reply With Quote
Old 05-11-2004, 04:24 AM   #5 (permalink)
I'm a Mac
zoni's Avatar
View zoni's Photo Gallery
^ thats impossible guys... there is no way for the stock wiring to just get disconnected and reattached to another source.
the stock clock memory and the radio memory are hooked to the 20amp DOME fuse... this may be out. check it!
Dave Zoni
Latest 3S-GTE Swap Pics
zoni is offline   Reply With Quote
Old 05-11-2004, 01:50 PM   #6 (permalink)
Bingo Zoni_Camry. I just logged in to report the fix but it looks like you beat me to it.
It's the 20a dome light mini fuse. I decided to check all fuses and discovered the dome light fuse was blown. Replaced it and the clock and radio station presets look like they are now being retained when the car is turned off. And yes, equip is stock.
The fuse must have blown when I was installing the aftermarket antenna and searching for constant power and antenna power voltage.
Old 05-11-2004, 04:10 PM   #7 (permalink)
I'm a Mac
zoni's Avatar
i usually tend to figure out all the electrical questions on the board...
Dave Zoni
