ABS Light - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-11-2004, 06:24 AM   #1 (permalink)
View camry96's Photo Gallery
ABS Light
Guys,
I am driving a camry 5sfe with abs. I change my drive shaft today and the abs lights stay on. I tried to disconnect my Neg terminal on my batt to clear the code but to no avail. I check it out and the code was 35. Anyone can help me here? Any ideas or opinion is highly appreciate..
Thanks
camry96 is offline   Reply With Quote
Old 05-11-2004, 07:01 AM   #2 (permalink)
Grenaded piston
88 LE's Avatar
View 88 LE's Photo Gallery
You most likely messed up a abs sensor when you replaced the axle.
Not sure what code 35 is though.
"Skoolin' the unlearned!"
Old 05-11-2004, 08:27 AM   #3 (permalink)
Abs
we did not touch the abs sensor at all. we just take out the drive shaft and I have no idea why this happen.
Anyone have any further ideas or opinions??
Thanks
Old 05-11-2004, 03:24 PM   #4 (permalink)
View neck's Photo Gallery
was it the same drive shaft you put in?
96 camry V6
neck is offline   Reply With Quote
Old 05-12-2004, 05:40 AM   #5 (permalink)
abs help
yes, it is the same drive shaft i put it back. I checked it out today and it appear to be 2 codes. one is 35 and the other is 32.
my abs main unit is made by denso but license from bosch. is this mean my unit is make from denso??
Please help and waiting for your inputs..
Thank you very much
