if you can get it on a lift, it will make it soo much easier, but pretty much what they said.... putting it in is a little harder, first get some tranny fluid, cuz u will probably need to add a little, but put someon ur finger, and put it on the end that is going into the tranny. then slide that end in, then take the other end then slide the other end of the axel through the brake assembly, the tricky part is getting it lined up right so that it slides right through, if it doesnt, take the axel nut and screw it on to what little bit is sticking through, and use an impact gun or wrench what ever ur using and it should pull it right through the rest of the way, put everything back together, and ur done....
