3VZmz to 1MZ swap - Toyota Nation Forum : Toyota Car and Truck Forums
Closed Thread
Old 05-11-2004, 11:43 PM   #1 (permalink)
View rubicinc's Photo Gallery
3VZ to 1MZ swap
I have a donor '99 Lexus es300 with 1mz VVT engine. Does anybody know if engine subframe will fit 1993 3vz engine?
I am planning to swap everything(ECU, wires, engine subframe with engine and tranny), but I need to know if subframe is the same on 1999 and 1993 on the body side.
Have anybody swapped engine subframe from '99 or '94 to '93.
rubicinc is offline
Old 05-12-2004, 12:18 AM   #2 (permalink)
限界域への独走。
View mobes's Photo Gallery
I think they do, but I'm not positive. I would just try it, then if it doesn't fit, it won't be too much more work to move the new engine/tranny to the old subframe.
I also remember a post about the vehicle speed sensors being different, so the speedometer won't work with the new ECU without changing the sensor, then it'll work but it won't read the correct speed.
mobes is offline
Old 05-12-2004, 02:23 AM   #3 (permalink)
Banned
View Talisman's Photo Gallery
Didn't you post this exact same question somewhere else?
Talisman is offline
Old 05-12-2004, 02:29 AM   #4 (permalink)
View I4 to V6 Swap's Photo Gallery
They fit. I took a 98 camry and jammed it into my 92 camry. Everything matched up physically. The wiring on the other hand will be a different story.
I4 to V6 Swap is offline
Old 05-12-2004, 04:32 AM   #5 (permalink)
Grenaded piston
88 LE's Avatar
View 88 LE's Photo Gallery
Double posting / cross posting is not allowed.
Please read the rules if you haven't already done so.
http://www.toyotanation.com/forum/t1779.html
If you want to continue your thread you can do so in the general discussion forum (where your other thread is).
With that said I'm locking this thread.
"Skoolin' the unlearned!"
88 LE is offline
Closed Thread
