how to flush power str. fluid - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-13-2004, 05:50 PM   #1 (permalink)
View alobo18's Photo Gallery
I'm looking for instructions on how to flush out my power steering fluid on a 2001 Camry CE auto. Please help if you can, thanks.
alobo18 is offline   Reply With Quote
Old 05-13-2004, 06:23 PM   #2 (permalink)
View kazzXtrismus's Photo Gallery
why???
jack it up disconnect the lines at the pump let it drain....
put key in ignition turn it on to run with engine off,...
while both wheels are off the ground force wheels by hand to turn all the way in both directions...this empties the rack...
reconnect lines...
fill pump....
turn car on... fill pump...
turn wheel all the way to one side...refill pump...
turn the wheel all the way to the other side...refill pump.....
done..
do not over fill ....fill to cold line marking
kazzXtrismus is offline   Reply With Quote
Old 05-14-2004, 12:03 AM   #3 (permalink)
Grenaded piston
88 LE's Avatar
View 88 LE's Photo Gallery
^ Your forgetting one thing.
The power steering pump runs off the engine (crank). So theres noway it'll run with the engine off.
And you don't fill the pump. You fill the fluid reservoir (it takes Dexron II/III ATF).
"Skoolin' the unlearned!"
Old 05-14-2004, 04:38 AM   #4 (permalink)
Gen 4 XLE v6
jhbhatia's Avatar
View jhbhatia's Photo Gallery
i have been using the sucktion thingie that you use to remove snot from babies to vacumm the ps fluid and then i just refill with fresh one.
(also: i use a different snot-extractor for the brake fluid as well...used to do this yearly..but lately i've lost these sucktion thingies)
Desi Toyota Dude Here!!!
jhbhatia is offline   Reply With Quote
Old 05-17-2004, 11:52 PM   #5 (permalink)
read the post man its written right there..
fill pump....
!!!!!!TURN CAR ON!!!!!!... fill pump...
done..
if you have contaminated the system with another fluid or caustic material this is the only way to truely clean it out....
I once had a lady com into my shop after having put brake fluid in her system....baaad girl
Old 05-18-2004, 01:07 AM   #6 (permalink)
amerikim's Avatar
View amerikim's Photo Gallery
Whats best oil here in P/Steering, there are synthetics here too right? Want to make it this coming weekend project
old faithful
amerikim is offline   Reply With Quote
Old 05-18-2004, 07:24 AM   #7 (permalink)
Biscuit-Dough Hands
Lumberg's Avatar
View Lumberg's Photo Gallery
Just use Dexron. Dont' bother with "power steering fluid"
Lumberg is offline   Reply With Quote
