Clearing Trouble Codes in Airbag System - Need Some Help - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-13-2004, 08:48 PM   #1 (permalink)
View shackelton's Photo Gallery
Unhappy Clearing Trouble Codes in Airbag System - Need Some Help
I had the instrument cluster out today to replace some lights and after hooking everything back up the airbag light styed on. When I did the diagnostics I got a 22 code.
Did a search and I found this thread and followed the directions. My wife watched the airbag light while I alternated grounding the wires, even got the fast pulse on/off at the end which indicates it cleared (?) but then it stayed on again. I repeated the procedure 3-4 times with the same result.
What am I doing wrong? Is the airbag system being reset thern immediately picking up a new trouble code?
BTW, I have the whole dash apart (instrument cluster plugged in but sitting on the steering column) so is there maybe a grounding problem?
Thanks.
shackelton is offline   Reply With Quote
Old 05-13-2004, 10:17 PM   #2 (permalink)
Banning is an art.
Silver Streak's Avatar
View Silver Streak's Photo Gallery
It's not supposed to be a super fast blinking, so make sure that it isn't that fast.
Most importantly, make sure you use a very strong ground. If anything, take some jumper cables and connect to the battery ground. If you don't do it with a strong ground, the light blinks, but it blinks fast, not slow.
As well, make sure to hold the last ground wire as per the diagram. I highly doubt the cluster sitting on your steering column is causing the problem, especially if everything is plugged in.
Silver Streak is offline   Reply With Quote
Old 05-13-2004, 10:38 PM   #3 (permalink)
Ok, I'll try it again in the morning.
I used the motor mount where the O2 sensor wire bracket is. I'll do it again against the negative terminal on the battery (I'm using a pair of old multimeter probes with lengths of 16 gauge wire soldered to them).
That's what I thought.....we'll see what luck I have tomorrow.
Thanks for the reply!
Old 05-16-2004, 08:13 PM   #4 (permalink)
OK, I have tried to reset this thing about 25 times with no luck. I am using the negative terminal on the battery. I have the dash all put back together so everything is connected. The airbag light stays lit after the six or seconds after you turn the key to ACC or ON. After the reset procedure, I do get the fast pulse when I do the alternating grounding wire thing, but then it comes back on!!!
Any help would be appreciated.
Thanks.
Old 05-16-2004, 10:45 PM   #5 (permalink)
Anyone?
Old 05-17-2004, 02:48 PM   #6 (permalink)
I saw some mention in another post where the author asked if the second ground wire should be left grounded until the ignition is turned off. I don't see that anywhere in the factiry manual procedure.
Any ideas?
Old 05-18-2004, 12:44 PM   #7 (permalink)
Still lookin' for some help.....
Old 05-20-2004, 12:40 PM   #8 (permalink)
View rizzo's Photo Gallery
Just a thought... my airbag light came on due to a loose fuse. Have you checked your airbag fuses? Maybe they were blown.
1995 Toyota Camry LE 2.2 Automatic
rizzo is offline   Reply With Quote
Old 05-21-2004, 09:39 AM   #9 (permalink)
Fuses check out OK. I have gone through the entire troubleshooting section in the factory manual and cannot figure this out....
Old 05-21-2004, 06:45 PM   #10 (permalink)
Banning is an art.
I can't help you anymore....dunno what it is. My last suggestions...make sure you're doing the grounding in the right order. Make sure you hold that last ground down. Make sure you have a strong ground. Try using the diagnostic port in the engine bay instead?
Other than that, I can't think of anything else. If anything, drive up to a TN meet in TO and I'll give you a hand!
Old 06-06-2004, 12:07 PM   #11 (permalink)
Wink
OK, so I thought I'd give this a try again. I have used both the under dash and under hood terminal blocks without success.
So I had my wife do the wire grounding so I could watch the airbag light (she actually thought this was a better deal since she thought I was trying to deploy the airbag in her face
Turns out I am NOT getting a cofirmation flash, just the "22" trouble code as if I had it jumpered...
I have checked and double checked that I am using the right terminals....
Ready to take the damn bulb out.
Old 06-06-2004, 09:50 PM   #12 (permalink)
amerikim's Avatar
View amerikim's Photo Gallery
Never give up.
If you take the bulb out finally, at least know why you did.
Retrace all your steps, strip it down if you must, do over.
If your Airbag light is lighting up and resetting to 22, according to the book, check your ECU-B fuse and light circuit, then ECU-B fuse and airbag assembly.
Did you try the part about disconnecting your airbag? With your battery disconnected of course.
Better then having no light and the 22 Error, that points to replace airbag sensor assembly.
old faithful
amerikim is offline   Reply With Quote
Old 06-07-2004, 12:08 PM   #13 (permalink)
Yeah, I thought of tearing it all down again and seeing what I might have done wrong. Definitely will retrace my steps.
I studied the troubleshooting section in the factory manual last night and saw what you referenced (ECU-B fuse, etc.) and will proceed with that as well.
Thanks for the encouragement!
Old 06-07-2004, 12:29 PM   #14 (permalink)
Banning is an art.
Yeah, try to fix it...cuz if that light stays on, your airbag won't go off....
Old 06-07-2004, 12:47 PM   #15 (permalink)
View luisitol's Photo Gallery
sry to hijack the thread for a quick moment. if you take out the airbag, can you reset the ecu code or will it jsut alwasy stay there?
'93 Probe GT - Daily Driver
'93 LE - Show Car - Coming SOON
luisitol is offline   Reply With Quote
