Strut Question - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-14-2004, 02:41 AM   #1 (permalink)
Its still a Camry.
Camry_rider's Avatar
View Camry_rider's Photo Gallery
Strut Question
Latley I've been hearing a clunk noise from my passenger rear side of my car, I thought it was things in my trunk bouncing around. I took everthing else out and its still going on. Im begining to think that the strut it done for. When ever I hit a bump in the road it clunks.....mabey its time for those new springs and struts. What do you guys think?
1991 Lexus ES250, 2006 Nissan Altima 3.5 SE
Camry_rider is offline   Reply With Quote
Old 05-14-2004, 07:19 AM   #2 (permalink)
Lives For The Curves
View nort0188's Photo Gallery
Might be the strut mounts
If torque actually won races, wouldn't we all be driving diesels?
nort0188 is offline   Reply With Quote
Old 05-14-2004, 12:26 PM   #3 (permalink)
back again? yeah, i am.
Erbe's Avatar
View Erbe's Photo Gallery
open up your hood and check that the three bolts on each of the struts are tight
back for the very first time.
-pat
Erbe is offline   Reply With Quote
Old 05-15-2004, 08:16 PM   #4 (permalink)
Fooly Sik RE!!!
View Wibbit's Photo Gallery
i had the exact same problem, like a clunking noise from the rear...it turned out that the rear swaybar mount was loose and the swaybar was bouncing around when i went over bumps. i just tightened the bolt and that was it!
1996 5 speed Vienta V6 Touring
|Rays Engineering|TRD|Unichip|BMC|Magnaflow|Whiteline|BR IDE|Endless|
My Vienta Website
Wibbit is offline   Reply With Quote
Old 05-15-2004, 10:45 PM   #5 (permalink)
Why not?
LiLItalian's Avatar
View LiLItalian's Photo Gallery
i had that clunking noise in my car, the front driver and passenger and it turned out i needed new strut mount, the guys said that on most camrys, the strut mounts wear out prematurely.
SOLD!
97 Camry V6 TRD
Proud new owner of a 2005 Scion TC
5-speed baby!
Toyota = Love
LiLItalian is offline   Reply With Quote
Old 05-16-2004, 02:06 AM   #6 (permalink)
View g-fizzle's Photo Gallery
i also had that kind of noise before (gen3) and it was the strut mount. i just replaced the one making noise and that fixed it.
g-fizzle is offline   Reply With Quote
Old 05-16-2004, 04:24 AM   #7 (permalink)
Its still a Camry.
Im planning on a drop in the near future with front and rear white line sway bars with tokico struts, Ill fix it all then.
Old 05-16-2004, 01:32 PM   #8 (permalink)
Toyota Lover
KerTiZ's Avatar
View KerTiZ's Photo Gallery
How much are strut mounts ususally?
Car Domain Page
KerTiZ is offline   Reply With Quote
Old 07-16-2004, 01:38 PM   #9 (permalink)
View dstriebs10's Photo Gallery
if you are going to replace the mounts they are about 40 bucks a piece. If you are a Gen 3 and you still have the stock struts it is prolly a good idea to replace those also. If your struts are stock then there is a possiblity that the struts will mess up the new mounts. Prepare to also have to replace the sway bar links cause mine were stock and they were really rusted so i had to break them to get them off. Those are like 50 bucks a piece. It sure is damn expensive to fix a cluncking.
dstriebs10 is offline   Reply With Quote
Old 07-16-2004, 01:43 PM   #10 (permalink)
Sweet n' Lowdown
BLUEMEANIE's Avatar
Gameroom cash: $112150
iTrader Score: 9 reviews
View BLUEMEANIE's Photo Gallery
A. I have strutmounts for sale cheap. PM me.
B. check your endlinks. Its more likely that one of the endlink bushings tore if its comming from the rear since the front strut mounts are the ones with the bearings in them.
06 NB tC - OG Team HAMSTER - SUPERCHARGED
BLUEMEANIE is online now   Reply With Quote
Old 07-16-2004, 02:19 PM   #11 (permalink)
MOUTH SLAP!
Your Uncle Moe's Avatar
View Your Uncle Moe's Photo Gallery
Wait before you do anything.....
I had the same problem and it wasn't my struts at all. While your checking your struts check your Stabalizing bar and its bushings. I had also thought that my problem was from the struts but when I got the car up on a lift, I saw the stabalizing bar broken and the bushings missing.
96 Camry V6 LE & 90 Eagle Talon TSI (AWD TURBO)
"Love is all you need to know and all you need to know is love is all you need to know."
Your Uncle Moe is offline   Reply With Quote
Old 07-16-2004, 05:37 PM   #12 (permalink)
Traitor
View stock93cam's Photo Gallery
i thought he said passenger rear...hood's in the back now...crap where have i been...JK
Joined the dark side...
'04 HONDA Civic EX
stock93cam is offline   Reply With Quote
Old 07-16-2004, 08:47 PM   #13 (permalink)
98 Avalon's Avatar
View 98 Avalon's Photo Gallery
The rear clunk noise on my car was due to very worn rear sway bar bushings. I replaced them with Energy Suspension polyurethane ones.
98 Avalon is offline   Reply With Quote
Old 07-16-2004, 08:57 PM   #14 (permalink)
93 Z24 and 78 Bronco
Nick's Avatar
View Nick's Photo Gallery
strutmounts and/or upper and lower insulators, sway bar links are probably toast now too...
-Nick
Nick is offline   Reply With Quote
