Differential V6 - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-16-2004, 09:10 PM   #1 (permalink)
Camry LE V6 2001
View REDSOXTICKET's Photo Gallery
Differential V6
I have a 2001 V6 automatic camry and I need your help.
I located the differntial drain hex plug which I know it is the drain plug however when I looked for the filler bolt I noticed there were two 12mm bolts located at 90 degress of each other at practically the same location. One is facing up and the other is facing toward the side. They appear to be redundent but there must be a reason for two bolts.
How do I proceed to the next step if I want to fill up my diff. with fluid for this year 01 and model V6 camry.
Why two bolts?
Is the top bolt the filler and when the diff is full it overflows from the side bolt ?
REDSOXTICKET is offline   Reply With Quote
Old 05-16-2004, 09:31 PM   #2 (permalink)
Joe W's Avatar
View Joe W's Photo Gallery
The side plug is used to fill and check the diff fluid.When the lube runs out of the hole it's full.
Joe W is offline   Reply With Quote
Old 05-16-2004, 09:45 PM   #3 (permalink)
Boondock Saint
View 89SV21's Photo Gallery
Joe W is right. BTW go with synthetic ATF when ya fill up your diff. I did it on my 89 gen2 and it made the power transitions a lot smoother.
"Fur pie doesn't sell"
89SV21 is offline   Reply With Quote
Old 05-17-2004, 03:26 AM   #4 (permalink)
Grenaded piston
88 LE's Avatar
View 88 LE's Photo Gallery
redsoxticket,
Please don't double post.
Forum rules:
http://www.toyotanation.com/forum/t1779.html
"Skoolin' the unlearned!"
