I'm pretty sure it won't work because the supra caliper is larger and the bolt holes are farther apart. I think zoni is using the caliper relocater with camry v6 calipers.
you will have to custom make new brackets for them... the mounting holes are farther apart on the tt calipers i believe... ill take a look at my buddy's supra tomorrow and find out for sure, but i think they are wider. make the brackets, it will work! 300zx TT calipers too... same deal.
has any checked their stopping distance after the brake upgrade? cause from what i've brushed up on you end up loosing g's if the set up isn't balanced. so i was woundering if supre rear rotors will fit a camry also? if so... ericsol, can you make some adapters for that also?
i have the brackets as well as brembo supra TT rotors. The stopping power is amazing and is highly noticable singe there is no fade. From the research that I've done, the rear is same deal as the front... interchangable with a bracket, only problem is you lose the functionality of the hand brake as the disk is a combo rear drum. Wilwood makes a kit but its pricey as hell. $1400 range i believe. and yes, you do lose the ebrake in the process.
someone had it on their solara 13inch rears and 13.? in the front.
1997 V6 Camry XLE:JIC FLT-A1US Coilovers, JP Performance Headers & Y-Pipe Combo, TRD Front strutbar, TRD RSB set to "track", IS300 rims with 17x7 215/45/17 Z-rated Dunlops. H&R Hubcentric 5mm Spacers
AIM: xHerManJohnx Email:JTLCASTRO@yahoo.com
