Camry 2000LE tail lights problem - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-05-2011, 10:43 PM   #1 (permalink)
View Emad's Photo Gallery
I had a problem with my Toyota Camry 2000LE tail lights (license plate lights and two second lights) but I found three wires that supply the voltage to these lights disconnected then I fixed the problem and all the tail lights woking properly now but still I can see the tail lights fault indicatior in the dashboard after fixing the problem even after starting the engine how can i reset this tail lights fault indicator in the dashboard, my friend brought his scanner that he used to use with his car HONDA Civic but we could't find any fault code in the scanner how can I solve this problem?
Also I can see the check engine light and the oil light on in the dashboard but before starting the engine and once I start the engine these litghts disappear how can I reset these lights that apprear before starting the engine. Thank you in advance for your help.
Best regards
Emad is offline   Reply With Quote
Old 07-06-2011, 12:36 PM   #2 (permalink)
Gameroom cash: $304355
I would open up the loom of wires inside the trunk by the driver's side trunk hinge and check for freyed or broken wires. The wires inside there have a tendency to frey and break from all the flexing they are exposed to as the trunk lid is constantly opened and closed through the years.
"Also I can see the check engine light and the oil light on in the dashboard but before starting the engine and once I start the engine these litghts disappear"
What you are describing sounds like normal behavior. If there was a problem, these lights would stay lit after the engine starts.
Mike
Old 07-06-2011, 01:19 PM   #3 (permalink)
I checked everything and found 3 wires disconnected and connected them and all the tail lights working properly but still i see the tail lights failure sign in the dashboard how can i reset it? because i don't have any problem with the tail lights now.
Best regards
Old 07-07-2011, 10:14 PM   #4 (permalink)
Were these 3 wires in that loom of wires or right at the tail lights themselves? Have you opened up and checked that loom of wires in the trunk I mentioned?
Mike
Old 07-08-2011, 12:10 AM   #5 (permalink)
Mike
Yes,i checked that loom of wires in the trunk before that and as i told you found three wires disconnecred, connected them and solved the problem and all the tail lights working properly, but the problem the tail lights failure sign still available in the dashboard.
Regards
Old 07-08-2011, 01:40 PM   #6 (permalink)
You may still have several wires in there that are broken inside but have not broken through the insulation.
Mike
