2 screws on the left, 2 on the outside, 2 on the bottom, 2 on the arm rest, 1 in the magazine holder, take off the handle bezel and pop the door off... you need a phillips and a regular screwdriver, then once you get inside you will need just a 10 or 12 i forget which to get the outer handle off... 10mm i think... you have to then get the metal rods detached from the handle with either the flathead or some pliars, slide the plastic piece that holds the rod in to the side... then the thing SHOULD come out... i might be forgetting something here... but it should come off then i think.
GOOD LUCK!
