Take it to a shop and pay someone $5 to crimp it. Or like stated above, solder it. Just for kicks, have some heatshrink on hand to make it pretty.
Dr J
If the terminal doesn't have plastic insulation on it, I'd use a propane torch to heat it and flow some solder into it.
Dr J
thanks guys! I think I'll give the solder a try first. although I don't have a powerful-enough iron I think.
my iron is like 30 watts. think that'll be enough? or would a lighter work?
and I definitely keep heatshrink around. lol
I doubt the 30 watt iron or lighter will work; probably not enough heat. But it won't hurt to try. If the solder flows nicely into the wire and wets it, that's good enough.
okay, that's what I was thinking, but we'll see how it goes haha.
Thanks!
aka Waka Flocka Flame's best friend (BFF)
You want all components to be above the melting point of the solder so you do not get a cold joint.
Do it ghetto way and touch the solder to the iron, lol!
Dr J
And you'll get unreliable ghetto results because this just gets you a cold solder joint.
