reset ecu after intake/exhaust? any cons? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-20-2004, 04:32 PM   #1 (permalink)
View robehsi's Photo Gallery
ive had my intake for about 3 months and my exhaust for about 1-2 months. i have yet to reset the ecu but i want to know if its safe and how exactly to drive the car when the engine is relearning as to not hurt the engine. should i do it?
robehsi
robehsi is offline   Reply With Quote
Old 05-20-2004, 04:33 PM   #2 (permalink)
also what is the best way to reset the ecu... any other methods besides removing the battery cable?
robehsi
Old 05-20-2004, 04:35 PM   #3 (permalink)
permanent hiatus
ryuji16's Avatar
View ryuji16's Photo Gallery
theres really nothing to it. my battery has died on my countless times, meaning no power for hours at a time, nothing really changes too drastically. if you drive like a normal sane driver, im sure nothing bad will happen.
ryuji16 is offline   Reply With Quote
Old 05-20-2004, 04:38 PM   #4 (permalink)
how long do i disconnect the battery for? im certainly not a normal sane driver... im a pizza delivery driver =P. so just drive the car normal.... how long will it take for the ecu to learn?
Old 05-20-2004, 04:50 PM   #5 (permalink)
3s-gte in a Camry?!?
white90dx's Avatar
Gameroom cash: $307675
Everything will be fine right from the beginning. If it has already been more than a week since you changed any parts, there is no need to reset the ecu.
The easiest way on a toyota is to pull the EFI fuse - you can find it on the fuse panel in the engine bay. That way, you don't loose your radio presets.
Unless its a drastic modification (intake and exhaust don't really count), there isn't a need to reset the ECU. Personally, I wouldn't worry about it.
-Charlie
