Engine coolant drain plug
I have a 2001 V6 Camry.
The Haynes manual inducates there are two drain plugs, one in the front of the engine and one in the rear of engine.
I found the front plug however I could not find the rear plug.
I went to the Toyota dealer and looked on there computer. They show a different part number for both plugs. The rear may have appeared to look like a bolt.
Would anyone know where this plug is located in the rear of engine?
How much fluid would remain in the rear engine block if I were to drain the system without removing the rear plug?
I would rather remove the plug but if I don't then if I knew the remainig water left behind after the flush then I could adjust the antifreeze for the water left behind.
THX
