GTX/GTX HM/Mobil 1?
Hey all,
Got a quick question for you all. I've done a ton of research and have read all the threads I could on synth vs. conventional oil, but I'm still at a loss as to what I should do for my engine at the next oil change. The engine (3VZFE) has 151k miles on it, has run Castrol GTX in there for the life of the engine, changed it every 3-4k miles, and have kept up will all other maintenance as well. My quandry is whether or not to stay with regular GTX, go with high mileage GTX, or switch to a synthetic. THe car doesn't have any leaks that I can find, except for a small seep around the valve covers. The covers were replaced late last year, but they still let a little through now and then. I've heard that if there aren't any leaks to speak of, then bypass the high mileage stuff and stick with regular oil. If that's the case, then I was thinking of going synthetic, as if an engine doesn't have leak problems now, then synthetic might be okay. However, I'm aware of the issues of synth causing leak problems on an old engine from reading the old threads. What would you all recommend?
--==B. White==---
