Hi guys,
About 6 months ago my 1999 Camry died in the middle of the road. I called up places to find the best deal and I got one that gave me 2 years warranty. I took it there and they fixed it after 5 days.
After a month of using the car the check engine light comes on. I call him up and he tells me to come by so he can check what's wrong with it. I take it to him and says that one of torque converters doesn't lock right and that he will fix it.
About 2 weeks later the light comes on again. I contact him again and he says to bring it down. It takes me a few weeks to get it back to him and says that it's the same thing, but I shouldn't have a problem driving it. It will take him a day or two to fix.
I pick it up and the next morning when I'm driving to work the engine light comes back
so I call him up upset and he says to bring it down. That's when my credibility for him went down.
Just today I took it to him and wrote down how many miles it had because he was making a big deal about putting gas in it so he can test drive it. I tell him this time I want a receipt of the fixes he did. He hesitates a bit and says he doesn't do that because he doesn't want to show what he does. I tell him well I need something for my records. He then finally agrees to do it when I come back. This time he says it will only take 3 hours.
I come back to pick it up and I see a guy working on it just with the hood open. After 30 minutes of waiting he tells me it could be an electrical issue that the computer inside the car isn't communicating well that is why the check engine light keeps coming. He said that, that isn't under warranty and if he wanted me to diagnose it with him it would take days and that it wasn't a part covered by the warranty.
I was a bit upset because I felt he was lying to me in order to get out of the warranty and make me pay more. I checked my milage and it was still the same as it was when I left it.
Here's what the receipt reads:
Check engine light is on, diagnose and found code P0770. Road test vehicle and confirm transmission works perfectly including torque converter lock up. Replace lock-up solenoid as a courtesy If problem persists, it could be electrical problem and/or ECU
SOLENOID In-Line4 - Lock-Up
85420-20110
I am not sure what to do. I have googled the code, but need some help on what I should do. Should I go to different repairs shops that do transmissions and try to get a diagnoses?
Btw the light came back on just as I arrived home 2 hours ago.
