My headlights won't work??? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-25-2004, 07:55 PM   #1 (permalink)
View jiggy2dmax's Photo Gallery
For sum reason my headlights stopped working. The bulbs aren't blown and all the rear lights and side markers work, everything except the headlights. I tested the three prongs after I took off the bulb and theres no power. BTW no fusues are blown either,I checked the driver kick panel fuses and one box under the hood? ANy1 know why or how I can fix this?
jiggy2dmax is offline   Reply With Quote
Old 05-25-2004, 07:56 PM   #2 (permalink)
BTW its a 1988 camry.
Old 05-25-2004, 09:42 PM   #3 (permalink)
poor college student
userlain's Avatar
View userlain's Photo Gallery
battery ok? any water seepage that touched electronics?
'91 Camry @ ~162,900 miles
userlain is offline   Reply With Quote
Old 05-25-2004, 09:53 PM   #4 (permalink)
nope, idk wat to do.
Old 05-25-2004, 09:54 PM   #5 (permalink)
Pochacco Owns Me
atobe's Avatar
Gameroom cash: $407595
View atobe's Photo Gallery
are your wires ok? may be u got a broken wire somewhere
Old 05-25-2004, 10:02 PM   #6 (permalink)
I checked all the wires under the dash and they all seem fine.
Old 05-25-2004, 10:18 PM   #7 (permalink)
Rotor > Piston
powderblue91's Avatar
View powderblue91's Photo Gallery
have a multimeter?
-Eric
1991 SV21 DX - The slow
1990 FC3S GXL - The go
powderblue91 is offline   Reply With Quote
Old 05-25-2004, 10:44 PM   #8 (permalink)
DJModifyd
alex's Avatar
View alex's Photo Gallery
check the wires going to the headlights?
maybe the relay for the switch in the steering colum went out...or the actual switch?
check the relay pack and see if anything is bad in there
alex is offline   Reply With Quote
Old 05-26-2004, 04:18 PM   #9 (permalink)
How do I check the relay?
Old 05-26-2004, 04:55 PM   #10 (permalink)
Grenaded piston
88 LE's Avatar
View 88 LE's Photo Gallery
Theres a 40 amp fuse for the headlights.
Its located in a little box that connects to the positive (+) battery terminal.
Fuse box
Fuses
"Skoolin' the unlearned!"
Old 05-26-2004, 09:20 PM   #11 (permalink)
I'll check it in da morning. Thanx a lot for the pics. I do have a multimeter.
Old 05-29-2004, 08:45 PM   #12 (permalink)
Well I checked all the fuses, connections and everything else again. However now the parking lights stopped working to. If I pull the lever the high beams will come on and the turning signal also work. I think its the relay but I don't know how to check. Any other solutions?
Old 05-29-2004, 11:21 PM   #13 (permalink)
96 3MZ M/T
chronoti's Avatar
Gameroom cash: $303830
View chronoti's Photo Gallery
it could be the switch for the light's the high beams still come on with the parking brake lights on right? check the switch with the multimeter for contiunty for pins for the light's i have a 96 so i'm not sure what pins those are. it's a3 to a9 on the 96 but just do a google serch or call toyota and see. there also a passenger side kick panel fuse box you can check if you havent, but it doesnt seem like it would be a realy if the high beams work check to see when you turn the high beams on that the low beams get voltage then if they do then it should be the switch's fault (dont trust me on this)
^ and leaving it that way!
Old 05-30-2004, 02:11 PM   #14 (permalink)
The highbeams only work if I pull the switch forward, for example if you wanted to just flash them. The lights on the trunk don't work either. I dunno what to do. Is there any special wire I should check under the dash? I belive the one for the tail lights is green wire connectedto te fuse box. This also doesn't have 12 volt.Help SUM1!
Old 05-30-2004, 02:33 PM   #15 (permalink)
96 3MZ M/T
chronoti's Avatar
well just pull the plug for the switch and check it probaly just falling apart inside, check the see where you have continuty in it (off, parking, low beam, flash high, high on) as you progress there should be more continuty in the switch i belive if you dont get contiuty moving it the switch is bad, that or give up and only drive during the day
