I have a 1994 Camry that I just bought for $100. It works fine except the speedometer isn't functioning. I took out the speed sensor located on top of the Transmission. Inside the speed sensor is a shaft with a yellow plastic gear at the end. The gear is worn out which might be the cause of the broken speedometer.
What is that gear called?
Every single speed sensor that I look for online DOES NOT include the gear.
Does anyone know the name or perhaps even a part number that I can use to order. Thanks
Pix:
