Starting up problem
Possibly a sluggigh Idle Speed Air Control Valve
It's been awhile, so here is what I remember.
To try and clean it, with eng off, Ign sw ON, remove the intake air hose from the TB, you will see a square(rect) hole in front of the throttle plate, spray TB cleaning solvent in there(NOT CARB CLEANER), towards the bottom front of the TB you will see an electrical connector. work that connector in and out , you should hear the valve operate, repeat a few times than put the intake hose back and see what happens.
hope this helps
JerryR
yjryba<at>yahoo<dot>com
To contact me via Email
Replace Text within< > with proper symbols.
