1998 - 4 Cyl Camry - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-06-2011, 01:06 PM   #1 (permalink)
View reg828's Photo Gallery
1998 - 4 Cyl Camry
I reached 200K today and due for a oil change. I am told to use high grade or synthetic oil. I googled a bit a stumbled upon this site, can someone guide me as to what oil change should I get. I am a regular 5 KMS oil changer and I go to Mr. Lube in Richmond, BC
reg828 is offline   Reply With Quote
Old 10-06-2011, 05:42 PM   #2 (permalink)
Location: San Diego CA, Glen Cove NY,Fairford UK,Cedar Rapids, IA
Gameroom cash: $280492
View csaxon's Photo Gallery
Stick with whats beem working for you unless you have been burning oil. These lube joints are trying to upsell you for more profit.
It worked fine until I fixed it!
csaxon is online now   Reply With Quote
Old 11-05-2011, 11:41 PM   #3 (permalink)
84 Toyota Camry DLX 2.0L
Camry84's Avatar
View Camry84's Photo Gallery
Canada
Almost any of today's oils (using manufacturer's recommend grade for your climate and driving habits) if changed at the interval you specify will do fine.
I prefer using Mobile1 Synthetic 10W30 and a quality Wix filter but that's just my choice. It's most important to use the right grade (perhaps 5W30 there in BC during the winter months). If your car doesn't leak any oil, go with the lower viscosity, if oil pressure is low or you tend to have a leak or some blow-by then a little higher viscosity oil is probably needed. (Maybe even 10W40).
Synthetic oil is nice because it keeps the engine very clean inside, even at 200000 miles it's nice to have a clean engine. Some people might recommend an oil specifically for older engines but I doubt that's really necessary.
Whenever changing oil types or viscosity of oil it's a good idea to run the new oil for a little shorter time (or mileage) and changing it along with the filter so that, in the event it flushes out some crud, it gets that flushed out of there so the new oil will now keep the engine nice and clean inside.
Just my 2 cents on oil changes.
______________________________
Dave
1984 Camry DLX 2.0L S2-E
1994 Toyota PU 22RE
Camry84 is offline   Reply With Quote
Old 11-06-2011, 12:22 PM   #4 (permalink)
Gameroom cash: $304355
At 200,000 miles I would continue doing exactly what you have been doing to reach that mark. If you have been using conventional motor oil (not synthetic) I would continue to use that. I used to own a 98 Camry 4 cylinder (totaled in an accident 5 years ago) and the recommended viscosity for your car is 5W-30.
Mike
