es300 tb into camry - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-28-2004, 09:22 AM   #1 (permalink)
Mad Scientist
2wickedtoyz's Avatar
Gameroom cash: $248601
iTrader Score: 9 reviews
View 2wickedtoyz's Photo Gallery
es300 tb into camry
is the es300 tb compatible with a camry? cause i did the search but no results just a picture that shows a 1mz with the twin tb's i was woundering if that helps the car breathe better or what? i've seen it on a es300 before but not recently. any input?
[url]http://www.cardomain.com/id/wickedtoyz[url]
Camry Wagon Crew
2wickedtoyz is offline   Reply With Quote
Old 05-28-2004, 11:24 AM   #2 (permalink)
Rated H: Chikan Sukebe
Sportivo Concepts's Avatar
View Sportivo Concepts's Photo Gallery
Actually that is not an ES turbo, but the prototype Twin Turbo designed by Top-Line and my company a few years back.
But we split Top-line continued with production and everything and we was shafted left holding an empty bag.
Your not gonna get that in any ES due to the room in a ES engines bay, but it will fit a Camry. The problem is that the control modules and boost controllers are not compatible with US spec 1MZs.
That is why we are in the process of designing a new one a more efficient one than what Top-line did.
Edit: BTW that kit is gonna cost you anywhere between $5700 to $7200
Cars: 07' Caddy CTS 3K Miles & Dying
News: Accepting Pics/Articles For New Toy/Lex Scion Mag
Important Threads: Guide To Nitrous
Sportivo Concepts is offline   Reply With Quote
Old 05-28-2004, 11:52 AM   #3 (permalink)
Mad Scientist
i was just woundering about the tb not the turbo set up i wanted to know if the tb from an es300 would fit in place of the camry's tb without changing the ecu
Camry Wagon Crew
Old 05-28-2004, 01:32 PM   #4 (permalink)
There was a never a turbo for the ES and if there ever was, it will fit depending on the year, if the turbo was for the same year as your Camry then yeah it will fit, but you will have computer problems.
ECUs in the Camrys and ES are different. The ES share the same ECU as the Avalon.
I'm not saying its not possible, but your gonna have to swapp either the ECU or get new controllers for the turbo.
Old 05-28-2004, 01:35 PM   #5 (permalink)
it was all a dream
Thanked 4,294,967,295 Times in 4,294,967,294 Posts
View Ratko's Photo Gallery
You'd have to see if the mating end on the intake plenum is the same for the single and dual throttle bodies. Im assuming they are different because of the much larger volume of the dual TB or else the same plenum would create the same bottleneck as the single TB version.
So my answer would be about 90% chance a dual TB won't fit a car with a single TB intake plenum.
I swapped a 96 TB on my 94, and all was perfect except the mounting of the Throttle Position Sensor. The sensors plug was oriented to the opposite side of the engine bay and therefore the stock harness that plugged into it couldnt reach. So i had to take the TPS off the old 94 TB and attach it to the 96 TB. It's all purdy and rust-free now
ratko.org
Ratko is offline   Reply With Quote
Old 05-28-2004, 01:37 PM   #6 (permalink)
TN Ass Man
DrtySthV6SE's Avatar
View DrtySthV6SE's Photo Gallery
nevermind
Pioneer Premier, Elemental Designs, SoundSplinter, Resonant Engineering Audio, Stinger, Optima, Rockford Fosgate
DrtySthV6SE is offline   Reply With Quote
Old 05-28-2004, 03:34 PM   #7 (permalink)
Mad Scientist
sportivo stop posting cause i don't care about that turbo set up just the "throttle body" i'm interested in.
ratko:from what i've noticed is that the tb goes from two into one that's why i was woundering if it would fit also all the plenum gaskets are the same
DrtySthV6SE:what was youe input?
Camry Wagon Crew
Old 05-29-2004, 04:22 PM   #8 (permalink)
Mad Scientist
Camry Wagon Crew
Old 06-01-2004, 08:54 AM   #9 (permalink)
Mad Scientist
any takers?
Camry Wagon Crew
