Light Help NEEDED ASAP Big pics Sorry - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-01-2004, 05:07 PM   #1 (permalink)
Go camry goooooo
DrewsCam's Avatar
Gameroom cash: $184780
View DrewsCam's Photo Gallery
Ok for those that dont no i was having trouble like 2 weeks ago my high beam in my passenger side wasnt working cause a wire was ripped
So i got a new connector, all went ok yesterday but it was taped up so today i go and soder it and now it doesnt work
i only have a high beam and no low beam
Did the solder do anything, cause i even took it off anf still no low beam
Sorry for the pics but u need to see what im talking about
help please
set up yesterday
[IMG]
http://images.cardomain.com/member_i...87_64_full.jpg[/IMG]
todays
http://images.cardomain.com/member_i...87_63_full.jpg
could i mat have shorted something out, and no its not the bulb i already changed that
11/19/2007 Gen 6 08 Camry SE.
Rockland Toyota / Scion Showdown 4.0 Sept 26th
DrewsCam is offline   Reply With Quote
Old 06-01-2004, 05:08 PM   #2 (permalink)
Go camry goooooo
DrewsCam's Avatar
Old 06-01-2004, 05:09 PM   #3 (permalink)
Go camry goooooo
DrewsCam's Avatar
todays setup
Old 06-01-2004, 07:40 PM   #4 (permalink)
Go camry goooooo
DrewsCam's Avatar
no help
so many viewed but no help
cause for now i cant drive at night only one headlight
can you atleast tell me what each wire is for
yellow with red - power?
green and red - ?
black and red is the negative
maybe if i switch the green with the yellow one the low beam would work??
Old 06-01-2004, 08:18 PM   #5 (permalink)
Grenaded piston
88 LE's Avatar
View 88 LE's Photo Gallery
^ Use a DMM and test the wires.
Turn on the headlights and you should see +12V between one of the wires and ground.
Then turn on the highbeams and you should see +12V between one of the other wires and ground.
And the other wire leftover is the ground.
"Skoolin' the unlearned!"
Old 06-01-2004, 08:28 PM   #6 (permalink)
Go camry goooooo
DrewsCam's Avatar
see i hooked it up right it was fine yesterday but today when i soldered it, it stoped working like the bulb went on then cut out
what happened?
Old 06-01-2004, 09:27 PM   #7 (permalink)
Rated H: Chikan Sukebe
Sportivo Concepts's Avatar
View Sportivo Concepts's Photo Gallery
Can you meet up during the day this week or next? And do you any crimps, strips or crimp caps?
Don't use tape for permant electrical jobs, you should also crimp the wires to protect the wires from shorting and other elements.
Cars: 07' Caddy CTS 3K Miles & Dying
News: Accepting Pics/Articles For New Toy/Lex Scion Mag
Important Threads: Guide To Nitrous
Sportivo Concepts is offline   Reply With Quote
Old 06-01-2004, 09:37 PM   #8 (permalink)
Go camry goooooo
DrewsCam's Avatar
im going to try fixing this again
why you wanna meet up an do this, where could we
pm a number i can reach you at
Drew
Old 06-01-2004, 10:48 PM   #9 (permalink)
poor college student
userlain's Avatar
View userlain's Photo Gallery
what kind of sodder did you use? if you used rosin-core sodder you should desodder that and replace it with silver-bearing sodder.
'91 Camry @ ~162,900 miles
userlain is offline   Reply With Quote
Old 06-01-2004, 11:15 PM   #10 (permalink)
View KoboChan's Photo Gallery
i would say replace the whole wiring. i think patching will cause problem in the future because youre running some very high amps through that wire. if you dont want to replace the wires, you can always switch to HIDs (use the wires that were cut and feed it into the HID ballast)
'06 Scion TC Automatic
KoboChan is offline   Reply With Quote
