Is there any way to lower my antenna manually? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-02-2004, 09:33 PM   #1 (permalink)
View .tony. .riot.'s Photo Gallery
The antenna is just stuck up there and I would like to lower it, is there any way to do this?
.tony. .riot. is offline   Reply With Quote
Old 06-02-2004, 09:56 PM   #2 (permalink)
View I4 to V6 Swap's Photo Gallery
You can take the motor part apart and lower it. The metal washer on top screws off, and there are two screws in the trunk that hold the motor in place. Once you take the unit out there are screws on the motor unit itself. Take those off, and you can try to put the platic line back on track and it may work, or you can just wind it up to lower the shaft and leave it.
I4 to V6 Swap is offline   Reply With Quote
Old 06-02-2004, 09:59 PM   #3 (permalink)
I'll try that tomorrow then, thanks.
