Can't shift into 1st in my Mk. IV - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-04-2004, 02:28 AM   #1 (permalink)
View kenratboy's Photo Gallery
Question Can't shift into 1st in my Mk. IV
This is not a new problem, but my car (see sig) does not like shifting into 1st gear while in moting (going VERY slow) and sometimes, at a stop. It is a 5-SPEED obviously.
-In other cars with a stick, when moving at just a few MPH, you can slide it into 1st gear. On my car, I cannot, I need to double clutch with a blip of the throttle, then it goes in.
-Occasionally, from a dead stop, I cannot shift fron anything into 1st, I need to row thru a few gears before it goes in.
-There is no noise or harshness from 1st. Using and shifting OUT of 1st is just fine.
Whats up? Is this normal, or is this expected wear from 80k miles? I do not abuse the car, it's not that.
1997 Camry CE V6 5-speed!
Mods: Whiteline rear sway bar & nice tires.
2009 RAV4 Limited V6 4WD
Mods: nothing you would care about.
kenratboy is offline   Reply With Quote
Old 06-04-2004, 02:48 AM   #2 (permalink)
3s-gte in a Camry?!?
white90dx's Avatar
Gameroom cash: $308575
Not normal... (ok, its normal for a Subaru tranny... but it shouldn't be). For reference, my gen2 5-speed has the original tranny and still slides into first at 10 or more mph when I want it to... I blip the throttle (double clutching) to be sure, but I have never had a problem.
When was the last time the tranny fluid was changed? Issues like this often improve a whole lot after a tranny fluid flush.
Good luck.
-Charlie
Old 06-04-2004, 02:55 AM   #3 (permalink)
As far as I know, the tranny fluid is from the factory.
Old 06-04-2004, 02:57 AM   #4 (permalink)
white90dx's Avatar
There's your problem. You should probably be on your third batch of fluid... or maybe just your second. Change it and enjoy.
-Charlie
Old 06-04-2004, 11:52 AM   #5 (permalink)
it was all a dream
Thanked 4,294,967,295 Times in 4,294,967,294 Posts
View Ratko's Photo Gallery
My older gen3 v6 tranny used to do that. It was just old synchros.
My new solara tranny slides into 1st like ken griffy jr.
ratko.org
Ratko is offline   Reply With Quote
Old 06-04-2004, 12:40 PM   #6 (permalink)
Can I change the tranny fluid myself (well, easily), or should I drop it off at the shop for a few hours?
Old 06-04-2004, 01:51 PM   #7 (permalink)
white90dx's Avatar
Manual trannies are very easy to do. You will just need the right size sockets and a funnel with a hose on the end to refill the tranny.
-Charlie
Old 06-04-2004, 01:52 PM   #8 (permalink)
View dj14901's Photo Gallery
You can change the fluid yourself, just get a suction gun and some Redline Synthetic fluid for your transaxle. If you don't have one already, buy a Chiltons or Hayes manual, it'll walk you through the steps. After replacing my fluid with the Redline stuff, it's much easier to get into 1st gear...
I'm pretty sure I used Redline MT-90 (I can check at home if you need confirmation)...
HTH -
DJ
dj14901 is offline   Reply With Quote
Old 06-04-2004, 02:11 PM   #9 (permalink)
Hmmm, sound like a plan.
