SDV10 & VDV10 Sedan & Wagon 2/93-97 Camry / Vienta
Front Control Arm Lower - Rear Bush SPF1265K (2B,2T)
Front Engine Steady Bush SPF1348K (2B,2T)
Front Rack Mount Bush - Power Steering SPF1191K 1 Power steering (3B,1T) Front Sway Bar Mount to Chassis Bush SPF1132-**K 1 Measure bar diameter 18,20,23mm available (2B) Rear Control Arm - Outer Bush SPF1105K 1 Fits outer of both front & rear arms (8B,4T) Rear Trailing Arm - Bush Kit SPF823K (8B,4Tn)
You did order all these bushings right? Got any idea what's the thickness of the stock front swaybar? I just wanted to double check to make sure that these fit our Gen3. :smile:
