Another Whiteline bar squeaking... - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-23-2002, 08:34 PM   #1 (permalink)
Banning is an art.
Silver Streak's Avatar
View Silver Streak's Photo Gallery
This morning my car was totally squeak free...when I drove home from work, it was horrible! Every slight bump it was squeaking like mad...drove straight to Crap Tire, bought a tube of white lithium grease and jacked up the car at home. Took off the bushings and noticed (like Ratko) that the bushings were TOTALLY DRY! All the blue stuff leaked out. I poured in half the tube in one side, and the other half in the other side. Put everything together, took a test drive and it was all okay.
Just a note to everyone installing the bar...definitely use more grease than what the bar comes with.
Silver Streak is offline   Reply With Quote
Old 04-23-2002, 09:03 PM   #2 (permalink)
There is no substitute.
EKam's Avatar
Gameroom cash: $700765
iTrader Score: 6 reviews
View EKam's Photo Gallery
Hmm I wonder why I don't have that problem...??
I've had mine for almost 9 months I think.
18/6/08 - Sayonara Kamuri!
EKam is online now   Reply With Quote
Old 04-23-2002, 09:27 PM   #3 (permalink)
The TN dissapearing act..
Dark's Avatar
View Dark's Photo Gallery
Dickson's just a lucky bastard is all :grin:
CE is for "Cheap Edition"
Dark is offline   Reply With Quote
Old 04-23-2002, 09:30 PM   #4 (permalink)
it was all a dream
Thanked 4,294,967,295 Times in 4,294,967,294 Posts
View Ratko's Photo Gallery
I was just waiting for your bar to start sqeaking... Mine hasnt made a peep since the re-lube. Glad to hear you fixed the problem.
Yeah, good note to all, EXTRA grease up the bushings and a lil' on the bar too when you install pretty much ANY swaybar.
latez.
ratko.org
Ratko is offline   Reply With Quote
Old 04-23-2002, 10:38 PM   #5 (permalink)
Zzzz...Caught ya Sleepin'
View TRDCAMRY's Photo Gallery
How much did you guys pay for the Whiteline sway bar? I just bought an Eibach Pro Kit and KYB Gr-2 gas struts and want to install everything at once. Where and how much for the sway bar? Thanks in advance for the input.
TRDCAMRY is offline   Reply With Quote
Old 04-23-2002, 11:16 PM   #6 (permalink)
Luc
View Luc's Photo Gallery
Guys, next time, try to add some teflon tape where the bushing makes contact with the bar, and of course, add some grease. I did that to mine and Rookie Solara's TRD RSB and so far no noises. :smile:
As far as Dickson goes, his "solution" is just to turn the stereo's volume higher. :grin:
Luc
1998 Camry LE V6 S/C
2006 RAV4 LTD V6 AWD
Luc is offline   Reply With Quote
Old 04-24-2002, 12:55 AM   #7 (permalink)
Blazin...
SCEPTER300RR's Avatar
View SCEPTER300RR's Photo Gallery
wat's the best grease to use for the bushings?? im installing mine this weekend... any advice is appreciated thnx...
Neoscepter
SCEPTER300RR is offline   Reply With Quote
Old 04-24-2002, 01:08 AM   #8 (permalink)
Luc
Well, we just used whatever it was available, and found the thickest kind also. Then, we added this white-colored one also.
Luc
Old 04-24-2002, 01:12 AM   #9 (permalink)
Blazin...
hey luc wat is it called??
Neoscepter
Old 04-24-2002, 03:45 AM   #10 (permalink)
View woshiagni's Photo Gallery
On 2002-04-24 00:16, Luc wrote:
Guys, next time, try to add some teflon tape where the bushing makes contact with the bar <snip>
Hey Luc... just ordinary teflon tape? Like the 99 cent/roll kind you use for plumbing?
woshiagni is offline   Reply With Quote
Old 04-24-2002, 09:35 AM   #11 (permalink)
View NYCTRDCAMRY's Photo Gallery
why don't you guys use a greasable bushing,
its alot better. check out energysuspension.com and cross check the size with a greasable unit.
NYCTRDCAMRY is offline   Reply With Quote
Old 04-24-2002, 10:39 AM   #12 (permalink)
Luc
The white grease is called Sta-lube, a multi-purpose type used for ball bearings and CV joints, as I was told. The thick one is from Mugen, 100,000 # thickness differenciate grease, imported from Japan, it's as thick as caramel candy, if not more.
The thick one was applied to inside the bushings, and the white grease was applied to the brackets (outside the bushings) and top of the bushing.
Luc
Old 04-24-2002, 10:40 AM   #13 (permalink)
Luc
Yes, that's right, make sure you wrap a few times around; I added about 3-5 layers on each end.
Luc
Old 04-24-2002, 10:42 AM   #14 (permalink)
Luc
I agree that the greaseable bushings would be much better, but the difficulty lies with the bushing brackets, as that will need to be modified so that the grease can be applied.
Luc
