Brake fade... - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-11-2004, 09:05 PM   #1 (permalink)
Triple A Whore
Edmond's Avatar
View Edmond's Photo Gallery
Brake fade...
Hey all, I drove the Camry today and noticed some brake fading.
The initial bite was perfect, but it would fade at the end.
Any suggestions?
Edmond.
Edmond is offline   Reply With Quote
Old 06-11-2004, 11:16 PM   #2 (permalink)
TN Ass Man
DrtySthV6SE's Avatar
View DrtySthV6SE's Photo Gallery
sound like to me maybe your lines(pressure) or fluid, somebody should be able to give you a more detailed answer though
Pioneer Premier, Elemental Designs, SoundSplinter, Resonant Engineering Audio, Stinger, Optima, Rockford Fosgate
DrtySthV6SE is offline   Reply With Quote
Old 06-11-2004, 11:18 PM   #3 (permalink)
Gameroom cash: $147537
Don't think its fade if its the same every time you use the brake. Its fade after you drive for a while and stopped couple times.
Usually low cost/stock pads are like that, non-progressive. Increasing paddle travel doesn't increase stopping. Get some semi-metalic pads. MotorMaster one is ok. EBC Green is the best.
Oh maybe you need to change brake fuild too.
Old 06-12-2004, 01:44 AM   #4 (permalink)
cam2Xrunner's Avatar
Ebc greens are great if you don't mind changing your pads every oil change. Check out your brakes, rotors and fluid. The pads might be getting worn out. Change the brake fluid if you're changing the brakes. Make sure there is enough useable metal left on the rotors(using a micrometer) Min. machine to spec I believe is 1.030. A good pad to use is the akebono pro-act ceramics or dealer pads(same thing). Also upgrade to steel brake lines.
Old 06-12-2004, 07:59 PM   #5 (permalink)
View malukalu99's Photo Gallery
Hawk HPS
malukalu99 is offline   Reply With Quote
Old 06-12-2004, 11:50 PM   #6 (permalink)
amerikim's Avatar
View amerikim's Photo Gallery
maybe air in your lines or time for new fluid.
old faithful
amerikim is offline   Reply With Quote
