Oil In spark plug shafts - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-12-2004, 11:32 PM   #1 (permalink)
View Luspher's Photo Gallery
I recently ended up having to get my engine swapped as my old one seized up. The new one doesn't seem to be as powerful, and seems to have been sitting for a while. I wanted them to swap out the spark plugs so i had my old iridium plugs in there, but no such luch. I ended up having to go pick them up only to find that the spark plug wires were falling apart on the far left two and the rubber part on the bottom came off keeping me from being able to swap the plugs. ANYWAY. Here's the problem.
Problem : Oil in the spark plug (valleys?)
Engine : 5S-FE
I'm sitting here looking at the engine diagrams, and am not too familiar with how the engine is put together as i have never taken it apart. And I don't want to take off the valve cover without knowing what I'm going for. I'm guessing it's the gromets that need to be replaced, but i wanted a second opinion on it before i ordered the wrong parts.
Thanks,
Luspher
Luspher is offline   Reply With Quote
Old 06-13-2004, 12:30 AM   #2 (permalink)
限界域への独走。
View mobes's Photo Gallery
You're correct. The o-rings around the tubes are leaking. You'll want to relpace all 4 o-rings and the outer gasket on the valve cover. They may sell the gaskets as a kit.
mobes is offline   Reply With Quote
Old 06-13-2004, 12:54 AM   #3 (permalink)
Cool, thanks, you know what size those nuts are on the spark plug tubes?
Old 06-13-2004, 03:04 AM   #4 (permalink)
限界域への独走。
I'm not sure which nuts you're talking about.
I haven't worked on a 5S engine, so I couldn't tell you anyway.
Sorry man.
Old 06-13-2004, 01:47 PM   #5 (permalink)
96 3MZ M/T
chronoti's Avatar
Gameroom cash: $303830
View chronoti's Photo Gallery
hummm you can always try this i had that same problem with my sisters nissan(the plugs were almost under in oil) but all we had to do was change the spark plug lines, sounds so easy too, at the base where the boot meets valve cover it forms a little seal try that if i'm wrong it's good the change out those wires
^ and leaving it that way!
Old 06-13-2004, 06:15 PM   #6 (permalink)
Grenaded piston
88 LE's Avatar
View 88 LE's Photo Gallery
30mm
If you don't have a 30mm socket, a big cresent / adjustable wrench will also work.
"Skoolin' the unlearned!"
Old 06-13-2004, 10:42 PM   #7 (permalink)
Formula One Fanatic
andyman61's Avatar
View andyman61's Photo Gallery
i just changed the valve cover gasket. it's not that bad really, just need a 30mm socket. the four little round gaskets for the nuts came with the valve cover gasket, got the whole thing at carquest. if your engine is fairly old, it might be a good idea to change the valve cover gasket while you're there, as it has a tendency to leak in older engines.
Metal to burn, sparks to fly...
1992 Toyota Camry 5 Speed - 5S-FE....totally stock
andyman61 is offline   Reply With Quote
Old 06-13-2004, 11:55 PM   #8 (permalink)
Thanks much!
~Luspher
