How hard is it to change a gen radiator? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-16-2004, 02:55 AM   #1 (permalink)
Its still a Camry.
Camry_rider's Avatar
View Camry_rider's Photo Gallery
Well, the hair line crack on my radiator has taken its toll, and my Camry stays at the half mark when driving at 60 mph, so I think its time for a new radiator. How hard is it to change one? Im broke and don't mind getting my hands dirty. Wouldn't mind doing some dress up on the engine bay either
1991 Lexus ES250, 2006 Nissan Altima 3.5 SE
Camry_rider is offline   Reply With Quote
Old 06-16-2004, 03:22 AM   #2 (permalink)
Grenaded piston
88 LE's Avatar
View 88 LE's Photo Gallery
1. Disconnect the upper and lower radiator hose. Make sure the engine is cool before you do this.
2. Disconnect the hoses that goto the tranny. This is if you have a auto tranny.
3. Unplug the fans.
4. Unbolt the brackets holding down the radiator.
5. Lift the radiator out of the car.
6. Swap the fans from your old radiator to your new one. Also swap over the rubber bushings (there should be 2 of them) on the bottom of your old radiator.
7. Reinstall everything, fill up the radiator with a 50/50 mix of antifreeze and water.
8. Run the car with the radiator cap off and the heater on full blast to bleed the system. Keep an eye on the fluid level in the radiator and fill it up as it gets low.
Now would also be a good time to change out your thermostat. The thermostat is in a housing where the lower radiator hose connects to the engine.
"Skoolin' the unlearned!"
Old 06-16-2004, 03:32 AM   #3 (permalink)
View Nico's Photo Gallery
Compared to many other cars changing a Camry radiator is a really easy thing. No more than 15 - 20 minutes
Good luck !
Nico
Nico is offline   Reply With Quote
Old 06-16-2004, 05:07 AM   #4 (permalink)
Auto-Cross Addict
SmokingTires's Avatar
View SmokingTires's Photo Gallery
Bondo
Tac-weld maybe? Save some time
'88 Toyota MR2 N/A - Sold
'99 Miata Sport - Sold
'85 Corolla GT-S - Sold
'02 MR2 Spyder - C-Stock car
SmokingTires is offline   Reply With Quote
Old 06-16-2004, 05:21 AM   #5 (permalink)
Its still a Camry.
Thanx for the help. I thought the thermostat was behind the water pump????? Mabey thats the old way of doing things. I found a radiator on e-bay for $109 Since you say its about a 30 min job...Im guessing about 2 hours for me....40 mins to install, 20 mins of screwing around, and a hour trying to find the tools.
Old 06-16-2004, 09:13 AM   #6 (permalink)
Gameroom cash: $147537
You should do a flush while you're at it.
Old 06-16-2004, 10:05 AM   #7 (permalink)
Killa Clean Gen 3
View Gen3cruiser's Photo Gallery
He's buying a NEW radiator.
222,000 miles, dead, car wreck. RIP
Gen3cruiser is offline   Reply With Quote
Old 06-16-2004, 10:28 AM   #8 (permalink)
A SNAIL POWERS MY CAMRY!
View 5Sfte's Photo Gallery
Sometimes the clip holding the wire at the bottom center of the radiator can be a beeotch. I have had to break it in every case. I just use a zip tie in the replacement.
88 Camry 4CYL- Stolen, recovered, sold.
94 Camry 4CYL- Jacked up tranny, sold.
92 Camry 4CYL 4DR 5SPD- Ehh, it runs.
96 Camry 4CYL 2DR 5SPD- TURBO, 10PSI
http://www.myspace.com/camry5sgte
TN Map... Add yourself NOW!!!
5Sfte is offline   Reply With Quote
Old 06-16-2004, 04:26 PM   #9 (permalink)
Grenaded piston
88 LE's Avatar
The water pump bolts to a housing. The housing is bolted to the block. So its all bolted together.
Theres a neck (thermostat housing) that bolts to the front of the water pump housing.
The neck (thermostat housing) has 2 nuts. Once you remove the 2 nuts and pull off the housing you'll see the thermostat.
Make sure that you also replace the gasket for the thermostat.
I'll get you some pictures of it.
Old 06-16-2004, 06:59 PM   #10 (permalink)
Pochacco Owns Me
atobe's Avatar
Gameroom cash: $407595
View atobe's Photo Gallery
it's very simple you can do it 30mins when , go borrow a floor jack and some jack stands it'll make it easier when you re-attach the lower hose when you'r under the car
Old 06-16-2004, 07:01 PM   #11 (permalink)
Grenaded piston
88 LE's Avatar
Heres the pics.
Thermostat housing
Water pump housing w/thermostat housing removed
Thermostat housing with thermostat
Thermostat w/gasket
Thermostat & gasket
Old 06-16-2004, 09:01 PM   #12 (permalink)
"I BUILD SLEEPERS"
Wraith's Avatar
View Wraith's Photo Gallery
I just got my new Radiator ... And its not for a Toyota ... Its huge its 3" to 3.5" thick compared to stock which is 1" thick... And if I remember correctly its a 3row radiator also ...
MySpace:
http://www.myspace.com/335453
Wraith is offline   Reply With Quote
Old 06-26-2004, 10:35 AM   #13 (permalink)
View myoda999's Photo Gallery
Very helpful thread. I have to change the radiator in my 1997 Camry XLE (american/automatic/AC), because of a leak where the plastic housing and metal radiator meet. Can you guys recommend a good radiator replacement? I'm hesitant to put in another radiator with plastic. Is there a good all metal replacement radiator? I plan to keep my car for a few more years.
myoda999 is offline   Reply With Quote
Old 06-26-2004, 11:59 AM   #14 (permalink)
View Zrain's Photo Gallery
88
is that a 5s??
or a 3s??
(im lost!!! water pump on the top of the block and not low on it???)
1991 Toyota Celica Red, Gray Interior, 5spd, 2.2L
My New Toy 3-1-04
Zrain is offline   Reply With Quote
Old 06-27-2004, 01:58 AM   #15 (permalink)
Grenaded piston
88 LE's Avatar
Originally posted by Zrain
88
is that a 5s??
or a 3s??
3S-FE
The water pump bolts to the side of the block. However theres 2 halves to it, water pump itself and a housing.
Its the same way on a 5S-FE.
