here's the recomended schedule, do all of this and your engine should be happy
250 miles or weekly
- engine oil check
- coolant level check
- windshield washer level check
- brake and clutch fluid level check
- check tires and pressure
3000 miles or 3 months
- power steering level check (i'd do this every week, you're there anyways)
- check tranny oil level (again i do this every week)
- change engine oil and filter
6000 miles or 6 months
- inspect/replace wiper blades
- check clutch play
- check/service battery (not much to do there, maybe clean the terminals)
- check/adjust serpentine belt
- inspect hoses
- check cooling system (?? thermostat opening/closing? coolant colour?)
- rotate tires
15000 miles or 12 months
- check/adjust brakes
- replace air filter
- inspect fuel system
- check differential fluid level
- inspect suspension and steering systems
- check driveaxle boots
30000 miles or 24 months
- replace fuel filter
- change coolant (every 60 months for the red stuff)
- inspect the evaporative emissions control system
- inspect the exhaust system
- change tranny fluid
- change differential fluid
- check and tighten critical chassis and body fasteners
- inspect and replace if necesary the spark plug wires distributor cap and rotor
60000 miles or 48 months
- check valve clearance (that's a bit too hardcore for me)
- change timing belt (DO NOT stretch this past, change it earlier if you think you're gonna get caught doing it late)
- replace fuel tank cap gasket
- replace pcv valve
- replace spark plugs
-Nick
